Attachment 234272Fiber laser cutting machine to choose the most sophisticated optical fiber lasers, photoelectric conversion efficiency is extremely high, stable performance and service life of key components of up to 100000 hours.Don't need to produce process gas, air auxiliary cutting, optical fiber transmission, do not need to adjust the light path, without reflection lens, can save a lot of maintenance costs, optical fiber laser cutting machine is focused on the flare smaller, higher efficiency, better processing quality, with high strength and overall welding fuselage, after high temperature annealing, guarantee the high speed cutting stability, has the very good rigidity and stability, with precision ball screw, linear guide transmission operation, high accuracy, high speed.
Optical fiber laser cutting machine is suitable for stainless steel, carbon steel, alloy steel, silicon steel, spring steel, aluminum, aluminum alloy, galvanized sheet, aluminum plated zinc plate, pickling board, titanium sheet metal and pipe cutting.
Optical fiber laser cutting machine is widely used in sheet metal processing, advertisement sign word production, the production of high and low voltage electrical cabinets, machinery parts, kitchen utensils and appliances, automobiles, machinery, metal crafts, saw blade, electrical parts, eyes, leaf spring, circuit board, electric kettle, healthcare, microelectronics, hardware, knives, measuring tool, etc.
Optical fiber laser cutting machine that is due to the high speed development of structure of double cladding fiber laser and the success of cladding pump technology, and semiconductor laser technology mature, fiber Bragg grating score and the realization of multiple coupler vigorously promoted the development of fiber laser, the technology of fiber laser rapid ascension, and quickly developed into kilowatt power output,the propsect of laser cutting machine for sale is very good.
The difference between optical fiber laser cutting machine and YAG laser cutting machine
Fiber laser cutting machine and YAG laser cutting machine is very popular product in the laser cutting products, with its unique advantages, in a wide range of laser cutting products, favored by many manufacturers, however, how the difference between the two devices, choose the most suitable one, here I am in accordance with the optical fiber laser cutting machine and the application range of the YAG laser cutting machine, processing materials and so on to do a simple introduction.
Optical fiber laser cutting machine can not only do oblique cutting, plane cutting processing can also be cutting edge tidy, cut surface is smooth, without burr, cutting processing used in high precision requirements.Optical fiber laser cutting machine with high stability, and extremely fast cutting speed, 2 times that of ordinary laser cutting machine, in addition to this, the beam quality of excellence, make processing of higher quality, cutting more detailed.Widely used in sheet metal processing, aviation, aerospace, electronics, electrical appliances, tool processing, decoration, advertising, metal processing and other industries.
YAG laser cutting machine has a significant advantage when cutting metal materials, stable running, high processing quality, simple operation, is a very high cost performance products.Widely used in advertising signs production, the production of chassis cabinets, lenses, medical equipment, aerospace, lamps and lanterns, automotive, metal crafts, metal and other industries, for cutting stainless steel, alloy steel, carbon steel, silicon steel, spring steel, gold, silver, copper, and other metal materials has the very good processing effect.
