586,533 active members*
2,415 visitors online*
    Mar 2014
    4
    Question Routing plexi
    Hello all!
    I'm trying to cut 5mm thick plexi with a 1/4" 2 fluted up cut spiral bit using a cnc router. I am making lenses that will be back-lit for a nice glow effect.
    I've been having some problems and have been experimenting with feeds and speeds.
    Best i've come up with is 0.1 onion skin(the lenses are thin so the onion skin is necessary), 2 passes, 9500rpm, 5000 feed.
    I've found that the up cut bit eliminates the rewelding effect but the edges aren't as clean as i'd like them to be. Also, it has happened that the bit pulls up the plexi and ruins the whole thing.
    I think ill try 3 passes to minimize the risk of it happening again but i still have the feeling i don't have it right.
    i'd love some help, guidance, opinions and ADVICE please!
    I really hope to hear back soon.
    Thanks in advance
    Mar 2014
    4
    Re: Routing plexi
    I have settled on 0.5 onion skin, 9000rpm, 3600 feed with 2 passes. Every piece will need to be hand routered out after but it'll do.
    Adding more onion skin really helped keep the plexi from being pulled up and with a lower feed, the edges have smoothed out enough but it isnt perfect yet.
    I would still appreciate any tips, tricks or suggestions for routering plexiglass.
    Re: Routing plexi
    Try a single flute "O" flute bit.
    You should get a cleaner edge, and no melting. You're feedrate is probably on the low side.
    Try leaving a small amount of material for a full depth finish pass as well.
    Machine rigidity may have a lot to do with the edge quality.
    Mar 2014
    4
    Re: Routing plexi
    I will definitely keep that in mind for next time. I don't think we have any single flutes bits around here, I'll have to ask to have a few ordered in.
    Thanks Gerry
  1. Approaching machining plexi and acrylic
    By LaserGuided in forum Glass, Plastic and Stone
    Last Post: 03-27-2014, 10:37 PM
  2. Plexi Engraving Basics
    By M2@ASI in forum Glass, Plastic and Stone
    Last Post: 01-29-2013, 09:39 AM
  3. Routing MDF
    By PHSS in forum Material Machining Solutions
    Last Post: 12-31-2012, 08:22 PM
  4. part off tools for plexi/PC
    By ratindahat in forum Glass, Plastic and Stone
    Last Post: 12-02-2011, 03:14 AM
  5. Engraving plexi for Edge-lit designs; Proper bits, settings?
    By Harpy in forum Glass, Plastic and Stone
    Last Post: 10-20-2008, 03:41 AM
