586,525 active members*
3,288 visitors online*
    May 2013
    23
    Do you have a Shenhui Laser? Looking for support....
    Looking for some help on set up. Let me know and then I'll ask questions.
    Jeff
    Re: Do you have a Shenhui Laser? Looking for support....
    Just bought myself a SH-350 D two weeks ago. I'm completely new to laser cutters but I have learnt quickly and have tweaked my machine. If I can help I will....
    May 2013
    23
    Hey WolverineX,
    Thanks for the reply. What tweaks have you done? Our 150 watt laser seems like is not putting out to the max. I need to get some different lenses I know but other than that, any idea how I can tweak mine?
    Jeff
    Not so much tweaks - I basically went over the machine checking electrics were connected tight, all bolts and screws were in place, then cleaned all the mirrors/lenses with Isopropyl Alcohol, aligned them the best I could and got the focal length of the lens right. It cuts 3mm ply much better.
    In an attempt to level off the 'lumpy' bed I'll be using some alloy honeycomb and u-channel edging to make it nice and flat, and would like to replace the flourescent strip lighting for LED strips, but electronics are not my best topic!
    This is a good read.
    And so is this...if I can link to another forum?
    Cheers.
    Ian.
    Feb 2015
    What do you need i just went trough installation on corel x7 and win7,
  1. Thinking of buying a shenhui laser
    By desktoprouters in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-12-2014, 04:39 AM
  2. Shenhui Laser
    By hackahobby in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-19-2013, 01:02 PM
  3. Shenhui or WK Laser? Your Suggestion?
    By wolfau in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-29-2012, 03:35 AM
  4. Help Needed!!!! Shenhui Laser K40
    By cheethr in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-05-2012, 09:48 PM
  5. SHENHUI LASER
    By romuros in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-16-2012, 08:45 AM
