586,940 active members*
2,658 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > fanuc 21i-m parameter to change mdi from incremental to absolute
Results 1 to 6 of 6
    Jan 2007
    61
    Wondering if anyone can help when in mdi I want to move to my workoffsett but machine reads in incremental in mdi not absolute?
    Nov 2010
    89
    Re: fanuc 21i-m parameter to change mdi from incremental to absolute
    G90 change it to absolute and G91 to incremental. So G90 G54 should move it in absolute to your work offset.
    Jan 2007
    61
    G90 Doesn't work in mdi so I think its a parameter
    2932
    3401 bits 4 (MAB) and 5 (ABS)
    MAB Switching between the absolute and incremental commands in MDI
    operation
    0 : Performed by G90 or G91
    1 : Depending on the setting of bit 5 (ABS) of parameter No.3401
    ABS Program command in MDI operation
    0 : Assumed as an incremental command
    1 : Assumed as an absolute command
    Jan 2007
    61
    ok so changed the parameter it works but now there is no points in numbers on tool length and work offsets?
    2932
    Quote Originally Posted by binzer View Post
    3401.4 & 5 are identical in 21iM-A and 21iM-B they should have no effect on the decimal point display in the offset pages. Did you change any other parameters?
  1. Incremental Absolute Fanuc 16MA
    By botha.y in forum Fanuc
    Last Post: 01-29-2014, 12:51 AM
  2. Replies: 5
    Last Post: 07-18-2013, 10:59 AM
  3. From incremental to Absolute,
    By CharlieM in forum BobCad-Cam
    Last Post: 12-03-2010, 02:33 PM
  4. Absolute or Incremental
    By mikede in forum Haas Mills
    Last Post: 02-04-2007, 12:02 AM
  5. Absolute and Incremental
    By ACME in forum G-Code Programing
    Last Post: 09-04-2004, 11:45 PM
