586,354 active members*
3,019 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > HAAS SL-30 Chip Auger Problem
    Dec 2013
    I have a HAAS SL-30 with a chip auger on it. We are having problems with the fine steel chips falling through the perforations in the sheetmetal for the coolant drainage rather than traveling out the auger chute with the bigger chips. Does anyone have a work around for this?
    Mar 2010
    1852
    Re: HAAS SL-30 Chip Auger Problem
    That is perfectly normal. Not sure how you expect to keep fines out of the tray, but it is normal. You will need to clean the tray out once in a while. Either that or be very aggressive and make only BIG chips. There is no way to keep all chips out of the chip tray.
    Dec 2013
    I should have said that differently. I don't mean the "fines" what we are seeing is the standard "C or 9 shaped chip" getting through.
  1. Looking for a chip auger for Haas VF2
    By jstucken in forum Want To Buy...Need help!
    Last Post: 04-20-2012, 12:59 AM
  2. Haas Mini Mill Chip Auger
    By Tolesh in forum Haas Mills
    Last Post: 11-12-2011, 12:36 AM
  3. Haas replacment part for chip auger
    By Ziggy33 in forum Want To Buy...Need help!
    Last Post: 10-24-2011, 08:00 PM
  4. Chip Auger
    By jstucken in forum Haas Mills
    Last Post: 08-04-2008, 09:40 PM
  5. Chip auger on my 1999 VM24 problem
    By moldcore in forum Milltronics
    Last Post: 05-20-2007, 06:25 PM
