586,440 active members*
4,227 visitors online*
IndustryArena Forum > CAM Software > MadCAM > How to restrict cutter travel in 4 axis machining
    Dec 2011
    97
    When doing 4 axis machining, I'd like to limit how close the cutter can move to the chuck holding the part. I tried using region curves, but that didn't work well. What I really want is a clipping plane defined by its x value. Is there a way to do this? If it matters, I am doing a roughing pass.
    Mitch
    183
    Re: How to restrict cutter travel in 4 axis machining
    You can resize the madCAM region by editing the length of the cylindrical region.
    Attachment 233772Click image for larger version.
    You can also use a 3D-stock model. Just draw a cylinder surface and use it as your stock model for madCAM. The toolpath will only be created where the cutter is in contact with the stock material. This works for both roughing and finishing.
    /Joakim
    Dec 2011
    97
    I am using a custom stock model. Even though it ends at the same planes as a cylinder surface would, there are tool paths generated that are past the ends.
    Attachment 233776
    Dec 2011
    97
    Any idea why, when I use the stock model, toolpaths are generated which are outside the stock?
    183
    The stock model is not a restricted area. It's just the material to cut. The toolpath can be outside the stockmodel if not colliding with your 3D-model.
    I think the best way in this case is to create a stop-surface that you select together with your model. The toolpath will not pass over the stop-surface because it is part of your model.
    Attachment 234274Attachment 234278
    Attachment 234280
    I hope this will give you some help,
    Joakim
  1. Job assignments to restrict water line operation
    By MichaelHenry in forum SprutCAM
    Last Post: 05-29-2013, 11:19 AM
  2. need Z axis design advice- dahlgren engraver -> full Z axis- how much Z travel?
    By lkasdorf in forum Uncategorised WoodWorking Machines
    Last Post: 05-11-2013, 02:50 PM
  3. U Axis excess error + Y axis over travel?!!!
    By jaine in forum Uncategorised MetalWorking Machines
    Last Post: 01-09-2013, 06:45 AM
  4. x4 Y axis travel
    By cvafiadis in forum Syil Products
    Last Post: 11-12-2008, 08:54 PM
  5. restrict osnap to one plane?
    By T-bolt in forum Autodesk
    Last Post: 09-10-2003, 08:13 PM
