586,124 active members*
3,006 visitors online*
    Jun 2011
    26
    Siemens 810D Hardinge 600II control shutting down
    Hi
    Can anyone help? My Hardinge 600II with Siemens 810D control keeps shutting down and rebooting. It does this while both machining and when not. When it starts rebooting it continually does it and doesn't actually fully load up! I have to turn it off and and on to get it to load up fully... then after a short while it starts rebooting again....
    Mar 2010
    1852
    Re: Siemens 810D Hardinge 600II control shutting down
    Tough one! I would think that it is a bad switch, relay, or connection. Try having the cabinet open and watching it, in the dark maybe too!
    Can't help more without more information.
    Mike
    May 2012
    36
    Sounds like to me it's a software issue within Windows. Do you have a backup of the control software to reload?
    Mar 2010
    1852
    Quote Originally Posted by gunrights View Post
    WINDOWS?
    May 2012
    36
    yes Microsoft Windows.............. what do you think the operating system is behind the HMI. Embedded version of Microsoft Windows. I think if you push and hold either the number three or six key when it's booting it will take you into Windows. There should be a way of restoring. Make sure you backup your programs.
  1. Hardinge VMC 600II Air blast
    By Ph2011 in forum Bridgeport / Hardinge Mills
    Last Post: 08-30-2012, 07:36 AM
  2. SIEMENS 810D NEWBIE
    By bolton78 in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 02-27-2012, 10:03 PM
  3. Hardinge VMC 600II Power Up Problem
    By pit-bull in forum Uncategorised MetalWorking Machines
    Last Post: 08-11-2011, 02:06 PM
  4. Hardinge siemens 810d keeps turning off
    Last Post: 07-08-2011, 09:14 PM
  5. HELP!!! Smoked Spindle on Hardinge VMC-600II
    By Janos in forum Bridgeport / Hardinge Mills
    Last Post: 01-19-2007, 06:59 PM
