586,471 active members*
4,208 visitors online*
Results 1 to 10 of 10
    Apr 2014
    5
    Post PCB Engraving CNC
    I am a complete newbie, I want to make a CNC for PCB making purposes, can I use these electronics
    1. 2.6kg.cm Nema 17 stepper motor (CNC NEMA 17 Stepper Motor 5V 1 2A 2 Phase 4 Wire 2 6kg cm 1 8 Degree 3D Printer | eBay)
    2. Polulu driver (1pcs A4988 Stepper Driver Module Polulu Compatible for RepRap Prusa Mendel M6 | eBay)
    3. USB CNC Driver (4 Axis USB CNC Controller Cncusb Usbcnc CNC USB Alternative Mach3 Usbcnc 2 1 GE | eBay)
    I want to make something small like whiteAnt.
    And one extra question, I have seen buildyourcnc.com to use Belt and Pulley instead of Screw and Nut in many CNC machines, is that advantageous and reduce backlash error?
    I am a computer science engineer and have a little less knowledge in mechanics so please consider if any silly questions are made.
    -Thanks
    Dec 2007
    98
    Re: PCB Engraving CNC
    Dec 2007
    98
    I would be most interested to know if you or anybody else could make the CNC driver (4 Axis USB CNC Controller Cncusb Usbcnc CNC USB Alternative Mach3 Usbcnc 2 1 GE | eBay) into a cheap cnc laser open architecture controller.
    Apr 2014
    5
    Maybe, I can push it for cutting small pieces of wood to make a bigger one. I have to start with a small one to make a big, right?
    CO2 laser cost a lot, that I can't afford :-(
    Dec 2007
    98
    Quote Originally Posted by Jimut View Post
    You can always start with something cheap like this:
    DIY Laser Cutter
    Apr 2014
    5
    That looks interesting, how much can I cut by a 500mW laser? Can I cut a 3mm acrylic sheet? What factors depend on the wavelength of the laser diode?
    Apr 2014
    5
    How big can I make with two NEMA17? Please help
    Dec 2007
    98
    The stepping motor size has nothing to do with the X-Y size of the table, you can make It any size you want :-)
    Apr 2014
    5
    And the other answers?
    1. how much can I cut by a 500mW laser?
    2. Can I cut a 3mm acrylic sheet?
    3. What factors depend on the wavelength of the laser diode?
    I think you should place order for your required PCB at pcbmaking.com and I m sure you will get your job done quickly on affordable price. It provides professional PCB with Free shipping and big discount price. Good luck!
    PCB DESIGNE
  1. Replies: 2
    Last Post: 04-06-2017, 05:17 PM
  2. Engraving is engraving a double line
    By amy_stars in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-15-2014, 12:54 PM
  3. Chinese Laser Cutting and Engraving Machine TS-6040 60w - Engraving problem
    By Andriette in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-24-2014, 03:44 PM
  4. PHCAD setting cut after engraving deeper engraving
    By herby08 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-25-2012, 10:18 AM
  5. Distinction between laser engraving between special LGP engraving machine when produ
    By CUTCNC in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-21-2011, 09:46 AM
