586,399 active members*
3,090 visitors online*
Results 1 to 20 of 26
    Feb 2011
    212
    NEED HELP windows XP wont restart
    It is stuck on the start up page. I just bought this mill and have yet to run it nd I went to turn it on and it wont boot up/. I don't know what to do at this point . it has Mach 3 on it and is part of my controller so taking it in is not an option.
    Oct 2013
    57
    Re: NEED HELP windows XP wont restart
    It's waiting for something to load ... like a program or USB ... it could be as simple as a connection. Do the F8 ,,tap,tap,tap at startup .. then do safe mode. Go to Administrative tools/event manager ... check the logs to see what's hanging you up
    Feb 2011
    212
    Ok the safe mode hangs up as well . I can do the f8 thing and get to the menus but nothing seems to work . Would a XP reboot disk work?
    Oct 2013
    57
    It may help Try hitting Esc as it's loading ... if you can get a Blue screen it will tell you what's going on
    Just for the heck of it swap memory slots
    Oct 2013
    57
    I'm assuming you have a desktop ... maybe your keyboard is failing
    Feb 2011
    212
    I can try another one . Worth a shot
    Do you get to a "loading windows" screen, or does it hang in the bios?
    Any messages on the screen?
    Feb 2011
    212
    this is what I get
    How long have you left it like that? Try disabling audio and networking in the bios, and see anything changes?
    Chance are, though, that some files are corrupt and you may not be able to recover.
    Feb 2011
    212
    Wow . Just WOW.
    I have not even used it since I got it home. I had it turned on and that was it as I am waiting in my double pull breaker to come in. I am nit sure how to do the changes. I am a mill guy not a computer guy ( besides programming the mills.) I tried to leave it up for 15 min or so . I'm just disappointed right now .
    If for some reason it is messed up what can I do to get it running again .
    Feb 2011
    212
    so I am really thinking that it id the hard drive that went do the way I shut it down FAIL now my question is if I were to get a new hard drive what all is involved in getting this thing up and running .
    loading on a new version of mach 3 and setting up all the parameters ???
    if anyone is local to Rochester Hills and knows what to install and how to do it LMK
    Jan 2008
    940
    It sounds like maybe one of you IO cards came loose in transport. Open the computer up and take each card out and put it back in along with the ram.
    Feb 2011
    212
    well I did have it powered up and mach 3 was up but my power was not hooked up to the mill. so I don't think they are loose but I will pull stuff out and plug it back in worth a shot
    Feb 2011
    212
    Quick rundown
    Won't start in safe mode ..
    Won't load in regular mode.
    Removed the ram and re installed it .
    Made sure all connections are tight .
    No luck still stuck.
    I may pull computer out and see if a shop can get it going
    Jan 2008
    940
    Unplug the cnc and see what happens it may be hanging on that.
    Nov 2006
    227
    If you have multiple ram simms, try using only one. Eliminates bad ram...
    Make sure hard drive data cable is well seated. I have seen drives go bad if cable was only partially plugged in, but not always.
    Will the system boot to CMOS settings screen? If yes, you can verify ram, video, hard drive..., are present. Then you know if it is software/hardware.
    Feb 2011
    212
    it gets to the page that I have posted. I have the original owner helping me out now. I am taking the hard drive out tonight and taking it to him Fridayalongwith a new hard drive
    - - - Updated - - -
    Quote Originally Posted by fixtureman1 View Post
    Ill try that before I take the hard drive out. thanks
    Feb 2011
    212
    well the original owner and he was able to check the hard drive for me . ( after pulling the computer out and taking the hard drive to his shop ) Then coped the mach3 to a flash drive . Took the hard drive back home reinstalled it and tried starting it with only 1 ram in . Nothing still . tried a boot up disk I bought and it took me in loops. I went to buy a refurbished computer and just my luck I could the computer was a dud . looks like the only luck I have is bad luck at this point. so today I woke up at 4 am and went out to the garage and cleaned up some of my mess then plugged everything back in on the computer. the cpu fan was loose so I was going to buy another one for it . I went to work and then asked the owners brother if we still had any of the old computers collecting dust and sure as sh!t he game me 1 . so looking to start a rebuild today. I will try to use the old hard drive and go from there.
    Jan 2008
    940
    I would slave the hard drive and not change any files on it
    Feb 2011
    212
    so basically change them out ? with a patch cord ?
    they don't have the same style plugs ?
  1. Esprit wont run on windows 7
    By Protoconcept in forum Esprit
    Last Post: 08-11-2014, 06:24 PM
  2. Replies: 7
    Last Post: 04-06-2014, 12:07 AM
  3. Restart
    By jhersh in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-06-2008, 02:20 AM
  4. Need help installing windows 95 - cdrom wont read
    By Hack in forum Computers / Desktops / Networking
    Last Post: 02-15-2005, 05:03 AM
  5. Windows XP or Windows 2000 better with Mach2
    By Beezer in forum Mach Software (ArtSoft software)
    Last Post: 10-18-2004, 04:08 PM
