We have a Bridgeport VMC 760 / 22 that just won't run a full day without some sort of issue. Recently it was experiencing an MO1 overload which after some head scratching turned out to be caused by the operator throttling the coolant using the ballvalve mounted on the spindle. The coolant pump had been recently replaced and was really putting out some great pressure. Unfortunately the job being run required the side access doors be left open (big long part), this got messy. So the operator used the ball valve to bring the coolant flow down to a less messy flow. This caused the pump to draw just enough more amperage that it was tripping the MO1 breaker which was set at 2.0 amps. I have a new breaker which can adjust to 2.5 amps but have not installed it because since leaving the coolant flow at 100% it hasn't been an issue.
This next issue has been ongoing but had been overshadowed by the previous situation because the machine just wouldn't run more than 30 seconds without alarming. This problem seems to involve only the Y axis but there are times when we're not 100% certain of that. The history goes like this; The machine would run fine unless we shut it off at the end of the day, upon start up the next morning the Y axis would be way off (somewhere between .5'' and .625''). So we just didn't shut it off, that worked for a while. Then it began to make noises that at first just sounded like it was making a cut except it wasn't cutting at that point. It sounds like a low growl and is accompanied by a vibration you can feel thru the machine enclosure as well as the floor. I have heard it do it in both the X and Y axis, although to my knowledge it has never lost it's X position. We were having some following error issues but that was related to a poor way oil supply due to a dirty way lube tank. It has now begun to lose the Y position randomly without being turned off. I reduced the max rapid speed from 625 IPM to 500 IPM ( I had seen that solve a noise issue on a BP VMC 1000 a few years ago). I am wondering if the noises have to do with the potentiometer settings for the X and Y motors. I turned the Y-motor encoder a quarter turn to see if that would eliminate the position issue, no feedback on that yet. I welcome any and all thoughts on the subject.
