586,350 active members*
2,949 visitors online*
Results 1 to 10 of 10
    Apr 2014
    Question setup with pulleys: can Mach3 handle it?
    I am designing a new laser cutter and I plan to use a setup with pulleys and belts where both motors move the X and Y axis: when the motors turn to the same direction the X axis moves and when the motors turn opposite directions the Y axis moves.
    it's the first time I am using Mach3 and I couldn't find a way to configure it for this setup.
    is it possible or do I need to go after another program?
    Attachment 233508
    Re: setup with pulleys: can Mach3 handle it?
    Not possible.
    Jan 2006
    2985
    I think it is possible to get mach to move the axes how you want with the proper g code, but it would not be possible to display the actual X,Y coordinates of the tool so it would be quite cumbersome to use.
    Seems like it would be better to stick to a standard one motor per axis setup....
    Apr 2014
    I think it's possible to solve it with the use of Formulas... I will try when I have all the hardware ready...
    Apr 2014
    6
    I always use Mach3 because it is pretty intuitive (I'm not great w computers). I wouldn't change the program, but I would, as it has been suggested, use a motor for each axis
    Jan 2006
    2985
    If your intent is to make it challenging to control the machine, then proceed. If you want a working machine you can use, just do what everyone else does and make it a normal machine that mach3 will control out of the box. If it is even possible, you are in for a treat to reprogram the machine coordinates to read correctly. Circular interpolation (G2 &G3) will definitely not work, canned cycles won't work, homing would likely not work, etc.
    On top of that, you would be writing your own CAM software to control the machine and that would be a treat as well. Seriously, just be like everyone else.
    If you really want to be difficult, linuxcnc is more suited to to the type of modifications you would need to do to get it to work.
    Jan 2012
    53
    There are obviously some disadvantages with this setup. What do you think are the advantages? There's certainly nothing wrong with trying something different, but there should be a reason why you think it'll be better.
    Jan 2006
    2985
    Quote Originally Posted by Fred27 View Post
    Inertia of the moving parts is reduced so you get better acceleration, not worth the control trouble...
    Apr 2014
    I have a vintage Datacal plotter that uses this system and it's light, fast and very precise...
    Jul 2003
    1754
    I think it is called 'corexy' and I think there are kins already make for linuxcnc..
    https://www.youtube.com/watch?v=vAg6w2Gmx-g
    http://www.linuxcnc.org/index.php/en...-bot-ou-corexy
    may want to google translate..
    sam
  1. Mach3 setup help
    By Padrino in forum Mach Mill
    Last Post: 09-25-2013, 04:05 AM
  2. Mach3 Setup Help
    By Tazzer in forum Mach Software (ArtSoft software)
    Last Post: 07-22-2010, 02:06 PM
  3. Poly pulleys vs steel pulleys
    By ynneb in forum DIY CNC Router Table Machines
    Last Post: 03-10-2004, 04:01 AM
