586,776 active members*
8,655 visitors online*
Results 1 to 7 of 7
    Dec 2010
    7
    Syil stepper driver
    I was given a few Syil stepper drivers from a friend who said the BOB went out on his Seig SX3 mill and couldn't figure out how to connect the Syil drivers to his new BOB so he bought new drives and gave the Syil drives to me. can anyone help me with this? I found the pdf on the syil stepper driver here: http://syilamerica.com/product_docs/...per_driver.pdf
    My BOB has step+ step- dir+ dir- What goes where on this crazy syil stepper drive? Any help would be greatly appreciated! Thanks.
    May 2005
    925
    Re: Syil stepper driver
    The info you need is right there in the pdf you posted, printed pages 7 and 9.
    Pablo
    ● Distribuidor Syil en Argentina ● "www.syil.com.ar" ●
    Jun 2007
    3757
    Actually, quite nice drivers, as long as connectors to motor are not intermittent (read that as cr4ppy crimps on external wiring) and you don't get any shorts in wiring.
    I blew up a mosfet in one by using a motor that had very low inductance. Just replace mosfet and all is fine.
    Make sure enable line is in correct state, or nothing will happen.
    Dec 2010
    7
    I seen that but wasn't sure what was the step and what was direction on the drive. I hooked up my step+ and step- to cc+ and cc- and my dir + to dr+ and dir - to cw - but nothing happened. Any ideas?
    Jun 2007
    3757
    Here is the stepper manual. The enable (free) signal is probably not as you expect and is stopping it working. Leave (free) disconnected (It causes motor to freewheel)
    Driver pins as displayed on case
    PLUS can go to +5v. No resistors required in series with each input pin
    PLUS can go to +12v. 1K resistors required in series with each input pin
    PDF...
    Jan 2008
    32
    I know this is an old post however I've searched and can't find anything on the "timing requirements" for the Syil stepper driver. The driver PDF above doesn't say what the minimum or maximum timing requirements for this driver are. This thread comes up in Google searches so thought it might be useful if an answer can be added here.
    What are the minimum pulse or step timings for the Syil Supper Diver?
    Once I can get all the information together and can get my Syil X3S working on LinuxCNC I'll put together a post on the required settings for anyone else that wants to change over from Mach3. Unfortunately my Mach3 PC died so I don't have the original settings to help with setup.
    Jun 2007
    3757
    Quote Originally Posted by kiwibum View Post
    Minimum andaximum timings? On a squarewave? I bet the steepper motor misses steps before you hit that limit.
    If you don't backup for a year, you are prepared to lose a years work.
    Mach3 manual is quite concise and clear. Parallel port, pin numbers, and all.
  1. Replies: 0
    Last Post: 02-26-2013, 08:37 AM
  2. Replies: 39
    Last Post: 08-07-2010, 04:59 AM
  3. 6 leads stepper motor connect to TB6560AHQ stepper driver board
    By wf1318 in forum Stepper Motors / Drives
    Last Post: 07-25-2010, 08:19 AM
  4. Replies: 6
    Last Post: 05-13-2010, 12:52 PM
  5. STEPPER DRIVER FAQ {Stepper/driver amp per phase match.
    By huios in forum Stepper Motors / Drives
    Last Post: 08-27-2006, 02:43 PM
