586,956 active members*
3,095 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > CNC Wood Router Project Log > Mounting Three Water Cooled VFD Spindles on large CNC Routers!
Results 21 to 36 of 36
Threaded View
    My best friend has a thriving business which uses large CNC routers to make it's products! The problem is the length of time it takes to cut a full 4'x8' sheet of products! So I agreed to help him by custom designing all the mounting brackets to and up to five spindles on one machine! One of the criteria in which he insisted on, was the tight spacing between spindles! So after a few days in CAD, I created a design which placed the spindles 3.65" apart!
    After he approved my design, I ordered a large block of aluminum 4"x4"x26" and a 1"x4"x26"
    First thing I did was to put ink on the large block, scribe lines, and push the bar through the bandsaw using lots of wax! Now I have three pieces of from the large block, and the one smaller piece. One of the pieces from the large block is 3/4"x4"x26, and will not be used!
    Now I plan on making the two T-Slot plates, using the 1"x4"x26" bars. So I put two vises on the mill table and dialed them in. Next I milled the edges of both plates to exactly 4", so they can be held in soft-jaws. Now I can remove the hard steel jaws from both vises, and install the long set of soft-jaws. Next I milled a step in both jaws, while a plate was clamped on the vise floor.
    Using a large 5" diam face mill, I cut both sides of each plate to exactly 1" thick.
    Attached Thumbnails Attached Thumbnails Z-Project_0009.jpg   Z-Project_0010.jpg   Z-Project_0011.jpg
    www.widgitmaster.com
    It's not what you take away, it's what you are left with that counts!
  1. Crazy Idea - converting Air Cooled spindle to Water Cooled
    By BanduraMaker in forum DIY CNC Router Table Machines
    Last Post: 01-20-2018, 02:29 AM
  2. Off the Wall question on water cooled spindles
    By MFchief in forum Tormach Personal CNC Mill
    Last Post: 04-26-2014, 06:41 PM
  3. water cooled spindle vs air cooled
    By ken2010 in forum Chinese Machines
    Last Post: 10-21-2013, 06:03 PM
  4. Air or Water Cooled Spindles
    By NVTS in forum DIY CNC Router Table Machines
    Last Post: 09-21-2010, 06:32 PM
  5. Vision Engravers & Routers New Large Format CNC Routers
    By CNC602 in forum News Announcements
    Last Post: 09-22-2009, 10:56 PM
