586,399 active members*
3,110 visitors online*
    Dec 2004
    48
    unreliable y axis
    Ok I finally get my router going about 3 weeks ago everything works great. Did some test cuts works awesome. Yesterday I was cutting a grid pattern on my table the program is going good the next thing I know the y-axis goes in reverse crashing into the end so I stopped the program and tried to jog back to where it was supposed to be and the axis wants to run backwards. I can jog it and sometimes it goes the correct direction then the next time it goes backwards or just buzzes like it is up against a stop and won't move. The question is is it a motor problem or a drive problem. I am using Kelling 40 volt drives with 24 volt ps. 270 oz. steppers under mach3.
    Thanks Bruce
    www.wtxrcdog.com
    http://wtxrcdog.blogspot.com/
    Re: unreliable y axis
    Could be a loose direction wire, or a computer problem.
    Measure the voltage on the direction pin while jogging in both directions. It should be 5V in one direction, and 0V in the other direction.
    Dec 2004
    48
    Well I tried to trouble shoot my y axis I had a gecko 540 that I had for another project and I hooked it up and replaced the stepper motor and it works awesome.
    Thanks for the help
    Bruce
    www.wtxrcdog.com
  1. Replies: 16
    Last Post: 09-11-2017, 10:31 PM
  2. Replies: 0
    Last Post: 08-04-2013, 05:30 AM
  3. SSR and Kress unreliable?
    By jeeybee in forum CNC Machine Related Electronics
    Last Post: 09-13-2012, 02:59 PM
  4. Mach3 anyone find it unreliable
    By RonCooper in forum Mach Software (ArtSoft software)
    Last Post: 09-04-2011, 07:59 PM
  5. Unreliable, need help in setup
    By ptfo in forum LinuxCNC (formerly EMC2)
    Last Post: 07-31-2011, 10:41 AM
