Installed Ubuntu 12.04 than installed all of what I thought was required. After 2 days of upgrading adding. Linuxcnc won't run. I get the intial machine setup screen, the splash screen, but won't launch program.
The linux debug text file has the following
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
2611
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
In terminal mode lists this;
maura@ubuntu:~$ cd linuxcnc-rtos
maura@ubuntu:~/linuxcnc-rtos$ . scripts/rip-environment
maura@ubuntu:~/linuxcnc-rtos$ linuxcnc
LINUXCNC - 2.5.2
Machine configuration directory is '/home/maura/linuxcnc-rtos/configs/stepper'
Machine configuration file is 'stepper_inch.ini'
Starting LinuxCNC...
hal_parport: dlopen: /home/maura/linuxcnc-rtos/rtlib/hal_parport.so: cannot open shared object file: No such file or directory
standard_pinout.hal:5: /home/maura/linuxcnc-rtos/bin/rtapi_app exited without becoming ready
standard_pinout.hal:5: insmod failed, returned -1
Shutting down and cleaning up LinuxCNC...
Cleanup done
LinuxCNC terminated with an error. You can find more information in the log:
/home/maura/linuxcnc_debug.txt
and
/home/maura/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
In your explaination PLEASE be gentle. I'm new to linux. http://www.cnczone.com/forums/images/icons/icon11.png
