586,461 active members*
4,844 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > Some 3D machining video on the Torus Pro-S today
Results 1 to 15 of 15
    Mar 2011
    480
    This part was made from 2.5x2.5x3" 6061 stock and required 5 jobs (HSMworks terminology for re-orienting the stock). I wanted to machine 1.125 dia. hole and perimeter to full depth from one side. Depth was ~ 2" but I didn't have a tool with flutes long enough to reach without rubbing the shank so I made one. I took a 1/2" end mill with 1.5" flute length and ground down the shank and flutes leaving only 1/2" of flute ant the bottom of the end mill. I did this by (go ahead and laugh :-), mounting a hand held grinder in the vise and ran the Tourus spindle at ~1000 rpm. Then slowly ground from the top of the shank downward. I only left 1/2" of cutting flutes due to the super long stick out from the tool holder. I took conservative cuts on the finishing passes and it all worked out well. Here's some video.
    I need to look into some more tooling (boring bar etc).
    https://www.youtube.com/watch?v=eeBw...ature=youtu.be
    7063
    Re: Some 3D machining video on the Torus Pro-S today
    Very cool! I'll have to remember that endmill trick - I sometimes want to cut deeper than the tools I have on-hand.
    Ray L.
    Jun 2004
    6618
    Cool stuff. That is a neat trick with the end mill.
    Lee
    May 2009
    327
    Moutainbike stem? I have a buddy of mine wanting to do a bmx stem. Not looking forward to flipping the thing a 4 times...
    Mar 2011
    480
    Yes it is. Without any fixturing, flipping and indicating in the vice is a pain. I don't have a decent vise stop YET. I always struggle with accurate positioning unless I make a fixture.
    Mar 2011
    480
    Mar 2011
    480
    An updated version. This is the "All Mountain stem", alodined gold. Stock before machining. 1.8 lbs. Part after machining. 203 grams.
    https://www.youtube.com/watch?v=C1PoBTW714k
    7063
    Niiiiice! :-)
    Ray L.
    May 2009
    327
    Awesome!
    Jun 2008
    1082
    Nice!
    Where'd you get that little single-point thread-mill? What feed and speed do you run it at, and do you like the results?
    7063
    Quote Originally Posted by Hirudin View Post
    Nice!
    Shars has decent threadmills at "reasonable" prices, but you still better sit down before looking, as the "cheap" ones still start at about $50. McMaster-Carr stocks some as well. For holes as small as the ones in the video, makes a lot more sense to me to use a tap. Threadmills are great for larger threads, and oddball threads that you don't need often, as a single tool will do Metric and Imperial, internal and external, and a wide range of diameters and pitches, even completely irrational sizes (like a 1/4" diameter, 1mm pitch). And the finish on thread-milled threads is wonderful, especially in nice matieral like 316 SS. But threadmilling is slooooooow compared to tapping. Lots of manufacturers charts on-line to get feeds and speeds. The programming is dead-simple.
    Ray L.
    Nov 2007
    2151
    Very, well done!
    Man that thread mill is tiny.
    Great stuff .
    md
    Jun 2008
    1082
    Does Shars or McMaster-Carr have single point thread mills? I tried searching but didn't come up with anything. Maybe I'm not using the right terms (or maybe their pictures are wrong).
    I see that Maritool has quite a selection of lil' single point mills.
    7063
    Sorry, I meant Maritool, not Shars. I always get those two mixed up....
    Ray L.
    Mar 2011
    480
    That was a lakeshore carbide thread mill cutting 5mm threads. Scientific tool also makes nice threadmills. Slow, but the threads are beautiful. I can drill at the low end of the minor diameter and get some tight threads. The cap screws screw in by hand super smooth and tight. Still would like to get a tapping head as threadmills are $$.
  1. Torus Pro vs Torus vs Pulsar vs PM45-CNC
    By Titaniumboy in forum Novakon
    Last Post: 01-28-2014, 06:47 PM
  2. Machining ceramic on the Torus-Pro
    By AUSTINMACHINING in forum Novakon
    Last Post: 01-25-2014, 05:21 PM
  3. New Torus Pro Ordered Today
    By UniqueMachining in forum Novakon
    Last Post: 06-13-2013, 10:51 PM
  4. Replies: 1
    Last Post: 08-23-2012, 09:22 AM
  5. Machining Video
    By cncadmin in forum Community Club House
    Last Post: 10-29-2004, 10:51 PM
