586,655 active members*
2,287 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Lathe usc will not update to dia. mode
    Dec 2007
    341
    I recently changed to a new PC and since I have the USC for Diam. mode will not change to X Z coordinates stay's stuck in XYZ , things I have tried.
    Uninstalled BCC V26 reinstalled
    Defined a new lathe in machine set up
    Changed in preferences to lathe Dia. mode
    Tried making it the default no luck either
    I am lost at this point and the program is of no use to me in lathe mode, any help would be greatly appreciated
    Dec 2011
    361
    Re: Lathe usc will not update to dia. mode
    Woffler,
    If you are trying to get the coordinate system to update to lathe mode, it is very simple. Go to Modules/Turning Mode and this will change the coordinate to X in Y and Z in X. You can set this to be the default under Preferences/Setting Default/Units.
    Dec 2007
    341
    Thank You ,I had forgotten about the module button as it has been awhile since I used the lathe function of BBC.
    I mostly use another program for my lathe ,and I was trying to program all the part in one system.
    Again Thank You for your kind response
  1. What is - Torque Mode? Position Mode? Speed/Velocity Mode?
    By sunmix in forum Servo Motors / Drives
    Last Post: 01-20-2024, 10:34 AM
  2. Tormach lathe update soon!
    By Wog in forum Tormach Personal CNC Mill
    Last Post: 11-16-2012, 03:42 AM
  3. C6 Lathe Update
    By Journey_Man in forum Syil Products
    Last Post: 07-30-2008, 02:06 PM
  4. Lathe update?
    By Legion99999 in forum Syil Products
    Last Post: 04-25-2007, 02:46 AM
  5. Update Control lathe
    By bbrreid in forum Stepper Motors / Drives
    Last Post: 04-14-2007, 05:50 PM
