Where can I get a 0.3A fuse for a Leblond Makino with a 11m controler? I think this fuse is making my DNC from pc not work
I cant find one anywhere.
I've only ever found them thru Fanuc...Sorry..
Really they where not to bad as far as price either..These and the little "green" ones..
Check it for continuity with a VOM - it may not be bad....
I check it for continuity and it was bad and i can see the Little wire inside burnt in half.
If you have a special fuse type, especially if they are not easily available or cost a bit.
For test purposes I make up a temporary fix using either an inline fuse holder or whatever common fuse holder is at hand and wire it across the old fuse by removing the cover. This way you can use the ready available 3AG FastBlo type, once you know there is no further fault, replace this with the proper type.
Al.
I must of read your mine, I just got done doing that I found one close to the same amps .315 to get by a few days and get some ordered from Fanuc
Thanks for the help guys
Mitch
