586,329 active members*
5,059 visitors online*
Results 1 to 8 of 8
    Apr 2014
    2
    I/O 030 CHECK SUM ERROR
    We have a lathe with a 11T control. They just changed the crt, now every so often we get this alarm. Differant programs, differant tools. Maintance say it's a programming issue,but some of these programs have run for several years with no problems. So i'm left with trying to figure out the problem so they can run without issues. I really need help to fix the issue. Thanks
    Jun 2004
    511
    Re: I/O 030 CHECK SUM ERROR
    Sounds like "they" knocked a plug or wire loose. Some connection issue would be my guess.
    Aug 2011
    2517
    possibly some kind of electrical interference has corrupted the battery-backed memory. try clearing the memory and re-load parameters. be sure you back up parameters first BEFORE clearing.
    Oct 2013
    57
    Fault cause
    .Measuring system not connected
    .Cable damaged
    .Glass scale dirty or damaged
    .Scanning head damaged
    .Measuring system supervision damaged
    My guess is it's a position feedback device ... probably an encoder thats on the way out or got coolant in it. Hard to find but easy to fix.
    Feb 2009
    6028
    I'm guessing they knocked something loose changing the CRT, like the I/O board mounted on the CRT frame !
    Sent from my G-Tab Quantum using Tapatalk
    Oct 2013
    57
    Maintance say it's a programming issue,but some of these programs have run for several years with no problems. ...
    Duh, only a maintenance person that's clueless about computers would say that. Shake your head yes and whatever you do don't let them within a foot of your machine. Sounds like the maintenance crew who took an almost brand new Mazak apart trying to get it to start ... turns out the Bijur was empty. Yes sur, them computer machines is just like my truck ... all they needs is some duct tape and a good ass-kicking
    Apr 2009
    1379
    This does NOT indicate a fault in the program , nor is it a battery problem. It is most likely a BMU problem.
    This alarm indicates that a discrepancy exists in the part program directory on the BMU (or equivalent).
    If possible, save all parameters (PC parameters can not be transferred through the serial poet), offsets, programs etc.
    Power the control ON holding the + and - buttons until the IPL menu appears.
    Choose CLEAR and press INPUT PB)
    enter '7' and press INPUT PB
    enter '15' and press INPUT PB
    enter '6' and press INPUT PB
    enter 'Y' and press INPUT PB
    The control will be back to normal, without the part program.
    Aug 2017
    3
    I just had the same problem. What fixed it was to reload my bubble memory from scratch. Luckily I bout a Memex card that allowed me to do this with 2 buttons.
  1. HI SPEED CHECK ERROR WHAT AM I MISSING
    By colby2000 in forum CNC Swiss Screw Machines
    Last Post: 02-11-2013, 07:15 AM
  2. M1 Sum Check Error
    By apylus444 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-30-2008, 03:10 PM
  3. mazatrol m-2 sum check error
    By bishop world in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-27-2007, 12:05 AM
  4. 22 Sum Check Error
    By ACE1553 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-12-2007, 03:12 AM
  5. Processor check error G
    By PeteB in forum Bridgeport / Hardinge Mills
    Last Post: 01-26-2007, 03:40 PM
