586,721 active members*
3,304 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach3 modbus settings with Hitachi WJ200 - so close yet so far
Results 1 to 11 of 11
    Jun 2008
    15
    Question Mach3 modbus settings with Hitachi WJ200 - so close yet so far
    Hello - I've been pulling my hair out trying to get Mach3 control of my Chinese 2.2kw spindle with modbus through a Hitachi WJ200. Unlike many of the threads I've read on the subject, I've gotten past the point where my rs485 converter is talking to the Hitachi. I can open the serial port and read registers from the WJ200, I just can't get Mach3 to control the spindle. I believe I've got some dumb error on the Mach setup screens or the brain config. Attached are screenshots of all the applicable (I think) settings. If you see anything obviously wrong, please let me know.
    Kent
    Jun 2008
    15
    Re: Mach3 modbus settings with Hitachi WJ200 - so close yet so far
    Any suggestions on where I should look to debug this? This is the last item left to finish on this project.
    Kent
    Hitachi makes good drives. Their manuals are horrible though. It is very hard to understand & find info.
    Nov 2014
    I have the same setup: WJ200, 2.2kw, using Mach3. Has anyone figured this out? What was the solution? Can somebody send me your brains file? The spindle isnt moving at all, and not sure where to start debugging
    Nov 2008
    412
    I have the sme problem with my Hitachi VFD. Give up the fight, sooo, now the on/off function is controlled by Mach3 and speed is controlled by potentiometer installed near the keyboard.
    Forget about global warming...Visualize using your turn signal!
    Jun 2008
    15
    Sorry for not having updated this old thread, but the solution I found was to try a different eBay RS485 converter. At only about $5 each, I bought a couple more from different sellers and all the problems were solved. I then found after a couple months of non-use that the spindle stopped working again. I broke out the spare converter and I was back in business. Lesson learned - always keep a few spares on hand!
    Nov 2008
    412
    The problem for me was that I couldn't set the rpm's right. The pulley setting did not have any affect at all.
    Nov 2014
    Quote Originally Posted by kbmyers View Post
    Do you recall which one you bought that ended up resolving the issue? We also bought a cheapy, so I wonder if this could be our problem as well. Thanks!
    Oct 2005
    58
    I do not have the RS485 interface in use so I really no knowledge of this area. But when looking at the screen shots provided the "Relay control - Clockwise M3" value is set to 3 and the "CCW M4" is also set to 3. Is this correct that the same signal is used for opposing directions?
    No, it would send both CW and CCW signals to the drive at the same time.
    However, most router users only use CW, and have no hardware wired for CCW. In that case, the Output 3 in the CCW field doesn't do anything.
    Hi
    My Hitachi X200 vfd just went up in smoke, been working great for years, was using Mach3 to control the VFD thru modbus. Just changed out the Hitachi drive to the new WJ200 series. Now I can not get the setup to work. Does anyone have the settings to use in Mach3 for WJ200? Plus I also need the brain file, and the parameters for setting up the WJ200 Hitachi drive
  1. Hitachi WJ200-007MF Setting Help
    By jckstrthmghty in forum DIY CNC Router Table Machines
    Last Post: 10-03-2015, 12:56 AM
  2. Hitachi WJ200 Settings Help
    By BanduraMaker in forum Spindles / VFD
    Last Post: 10-09-2014, 05:25 PM
  3. hitachi Wj200 error code
    By sharmallcarmal in forum Community Club House
    Last Post: 06-09-2013, 03:29 PM
  4. WJ200 + 1.5kWw Air-cooled, am I missing any settings?
    By ironspider in forum Phase Converters
    Last Post: 05-01-2013, 11:44 AM
  5. Mach3 with Hitachi VFD using Modbus
    By swinn in forum Mach Software (ArtSoft software)
    Last Post: 11-28-2008, 07:44 PM
