586,471 active members*
4,061 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport Interact Mk11 Series 1 - Spindle motor fan overload
    Apr 2014
    I recently started on a small project to get our CNC mill up and running. The electricians have come out and powered it up. The used a transformer to convert 415V to 230-240V for the controller which is a Heidenhain TNC2500. The mill boots up alright, tests the memory without any problems, comes up with power interrupted and then when I hit the CE button, it quickly says traverse the axes and then comes up with error 'SPINDLE MOTOR FAN OVERLOAD'.
    Is this a simple reset button on the motor or a relay? The sparky checked the output for the tranny and it was between 230V and 240V.
    Any information would be appreciated.
    Oct 2010
    1189
    Re: Bridgeport Interact Mk11 Series 1 - Spindle motor fan overload
    We did retrofit of Bridgeport which had an tnc2500 we have Parts to sell ..
    Gesendet von meinem SM-N9005 mit Tapatalk
  1. Bridgeport Series II Interact 2 -- how to remove top plate above spindle
    By ichudov in forum Bridgeport / Hardinge Mills
    Last Post: 12-17-2010, 10:55 PM
  2. Top spindle I.D. on a Bridgeport Series II Interact 2
    Last Post: 08-11-2010, 01:49 PM
  3. Bridgeport Series II Interact 4 Spindle Brake
    By UKRobotics in forum Bridgeport / Hardinge Mills
    Last Post: 04-27-2009, 06:22 PM
  4. BRIDGEPORT SERIES 1 INTERACT SPINDLE REPLACEMENT INSTRUCTIONS
    By RMARCH in forum Bridgeport / Hardinge Mills
    Last Post: 03-09-2008, 10:04 PM
  5. Identifying Bridgeport Series 2 Interact 4 Spindle Motor
    Last Post: 05-26-2006, 12:55 PM
