586,283 active members*
4,019 visitors online*
    Apr 2014
    SL-6A I/O 030 CHECK SUM ERROR
    I have a SL-6A with fanuc 11T control, and we started getting this alarm. The book does'nt tell how to go about to fix it or what is the cause. Need a little hepl please
    Aug 2011
    2517
    Re: SL-6A I/O 030 CHECK SUM ERROR
    The manual says 'The checksum in the page unit of the NC memory is in error'
    so that means you have a PCB fault. Possibly it's as simple as a bad RAM, or more complicated and one of the circuit boards needs to be replaced. Or maybe some data got scrambled in memory and a memory clear will fix it.
    you could try clearing the memory and reloading parameters etc and that might fix it. if you don't have a backup of the parameters and you clear the memory your machine will only be good for a boat anchor.
  1. HI SPEED CHECK ERROR WHAT AM I MISSING
    By colby2000 in forum CNC Swiss Screw Machines
    Last Post: 02-11-2013, 07:15 AM
  2. M1 Sum Check Error
    By apylus444 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-30-2008, 03:10 PM
  3. mazatrol m-2 sum check error
    By bishop world in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-27-2007, 12:05 AM
  4. 22 Sum Check Error
    By ACE1553 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-12-2007, 03:12 AM
  5. Processor check error G
    By PeteB in forum Bridgeport / Hardinge Mills
    Last Post: 01-26-2007, 03:40 PM
