586,077 active members*
3,591 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Current readout error on VFD
Results 1 to 4 of 4
    Dec 2010
    337
    I've just wired up my spindle and VFD. All seems well but the spindle current readout on the vfd seems way off for the spindle rating.
    I'm going to speak to the techs monday on the phone but in the mean time scratching my head. I've ordered a spindle mount which doesn't arrive until Tuesday so I can't mount the thing and monitor the current draw when under load and don't have a tachometer so cant check if the rpm's are correct for the freq.
    The voltage rises and falls correctly when accelerating and de-accelerating. between 0 and 220v. VFD is in constant torque control mode.
    The spindle is rated at 1.5kw, 8 amp, 220v (ebay chinese air cooled jobbie)
    VFD is a moeller DV51.
    The VFD is showing a current draw(from the spindle) of around 0.7amps when operating anywhere between 133-400Hz, and peaks slightly to around 1.7Amps when linearly de-accelerating to 0, at around the 50-100Hz mark.
    Any ideas why the spindle is drawing so little is this normal?
    Jul 2007
    265
    The spindle only draws what it needs, depending on the load. With no load the current should be very low. While milling it will be higher, probably a couple amps normally. 8 amps is the maximum it can handle continously, and it takes a lot to reach 8 A. That's a substantial load on the machine.
    Dec 2010
    337
    thanks tahustvedt, I was hoping that was the case.
    Sep 2008
    25
    Re: Current readout error on VFD
    You can use a power monitor. SymCom's Model 777-P2 series has great features. It's a little expensive and probably overkill in your case.
    SymCom Power Monitors & Overload Relays Distributors
  1. error: current tool path is not for 4 axis machine
    By greg2fs in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 03-31-2020, 11:55 AM
  2. Fanuc SV117 Current Conversion error
    By hiflyerint in forum Fanuc
    Last Post: 11-27-2013, 09:06 AM
  3. Fanuc SV117 Current Conversion error
    By hiflyerint in forum Servo Motors / Drives
    Last Post: 11-26-2013, 04:54 AM
  4. Error Code 32 (over current) at start up
    By GEC-ENG in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-17-2011, 01:54 PM
  5. Position Error Readout Ranges
    By jon_fallon in forum Fadal
    Last Post: 04-27-2010, 09:49 PM
