586,493 active members*
1,963 visitors online*
    Jan 2013
    KFlop/Kanalog/Mach3
    Waterjet. X & Y are servos. Z is a stepper. Upgrading from SmoothStepper because I want c losed loop control on X &Y with linear encoders.
    Everything setup on Kanalog. Can jog using KMotionCNC. Encoders are working in KMotion.
    1) Mach3. Config. Ports & Pins. Do I enter an address for Port 1 and 2?
    2) X & Y are analog. Do I enable them in Motor Outputs, or just the Z (stepper) axis?
    3) KMotion. Axis. Enable activates closed loop control. Hitting a limit switch disables. I am using Opto 6 and Opto 7 (Kanalog bits 150 & 151). How do I turn these on/off instead of Enable?
    3A) How do I turn Enable back on?
    May 2006
    4047
    Re: KFlop/Kanalog/Mach3
    Hi Kiethkyll,
    No. Parallel Ports are not used when using KFLOP. Just leave the defaults.
    Yes. Mach3 needs to have those enabled or it won't generate the motion for the axis. Enable them and set the to a dummy port like 0.
    I think you should do both. Disable the KFLOP Axis channel and the amplifier. See the watchenable.c example:
    Code:
    #include "KMotionDef.h"
    main()
    	for (;;)  //loop forever
    		WaitNextTimeSlice();
    		if (ch0->Enable)
    			SetBit(152);
    		else
    			ClearBit(152);
    HTH
    Regards
    TK
    http://dynomotion.com
    Jan 2013
    I am unable to home in Mach3. It zeros, but won't move stages. Don't see a message - doesn't look like it's calling the C program.
    Dell laptop. Windows 7 home premium. Latest version of Mach 3. Plasma config for Waterjet system.
    Do we have version issues?
    Followed this thread:
    http://www.cnczone.com/forums/dynomo...ml#post1457956
    I can jog all 3 axis. Encoders are working.
    May 2006
    4047
    Hi Kiethkyll,
    Did you make a C Program? If so please post it.
    Is it specified in the Mach3 | Config Plugins | Dynomotion | Home | Home User Program ?
    Are you pushing Ref ALL Home in Mach3?
    Try setting to the Mach3Home.c example to see if at least messages appear in the KMotion Console Screen.
    Regards
    TK
  1. Kflop + kAnalog+ Hurco KBM
    By k-linkz in forum Dynomotion/Kflop/Kanalog
    Last Post: 03-18-2014, 07:29 PM
  2. CNC upgrade with Kflop/Kanalog/mach3
    By Frank_W in forum Dynomotion/Kflop/Kanalog
    Last Post: 06-26-2013, 01:04 PM
  3. My Kflop/Kanalog test bed
    By PEU in forum Dynomotion/Kflop/Kanalog
    Last Post: 05-31-2013, 04:55 PM
  4. Retrofit old Cnc with kflop-kanalog
    By Scottburley in forum Dynomotion/Kflop/Kanalog
    Last Post: 02-23-2013, 12:49 AM
  5. KFlop + KAnalog hardware details
    By arvidj in forum Dynomotion/Kflop/Kanalog
    Last Post: 12-28-2012, 08:53 PM
