587,047 active members*
2,499 visitors online*
    Dec 2006
    One off machined aluminium plate
    I'm looking to get an aluminium plate machined. 100mm long, 50mm wide approx 15mm high with a curve machined off the top of the plate.
    The x/y/z dimensions are not critical (can be mm or cm bigger but not smaller) but the radius (105mm) of the cut curve is. The plate is for attaching some peltier elements to a metal keg. Machined finish is okay. I don't mind if I have to do some polishing myself.
    Looking for having one made for a prototype at this stage but might be more later. Have attached png and a zip with stl + step files (using Inventor Fusion, and can only export to sat, stp or stl).
    Shipping to Norway.
    Thanks!
    Feb 2014
    92
    Re: One off machined aluminium plate
    Can you let us know your email address at this email address [email protected], so that we can send you the quotation. Thanks.
    BR
    /Ryan Feng
    Sales Manager
    Proto Tree LLC
    website: www.prototree.com
    email: [email protected]
    Apr 2014
    4
    PM Sent
  1. RFQ - Aluminium Plate
    By zoransimeonov in forum RFQ (Request for Quote)
    Last Post: 04-23-2019, 11:36 AM
  2. Need letters machined into Aluminum Plate
    By andreej in forum North America RFQ's
    Last Post: 03-06-2013, 08:48 PM
  3. (4) pieces of 1/2" plate machined ASAP. RFQ
    By diyengineer in forum Employment Opportunity
    Last Post: 10-01-2010, 03:03 AM
  4. Is there any way to plate copper onto aluminium?
    By rkremser in forum Material Machining Solutions
    Last Post: 10-14-2008, 10:38 PM
  5. Rfq Machined Aluminum Plate
    By Philip in forum Employment Opportunity
    Last Post: 08-22-2006, 04:15 AM
