586,475 active members*
3,342 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > VAC III D-11 SPINDLE DRIVE PROBLEM
Results 1 to 13 of 13
    Mar 2009
    31
    We have a Cadet-V4020 with VAC III D-11 and got error message 082 ALARM P 1001FFFF. We found that the two fuses on power supply board on VAC III was blown they were fuses F2R AND F2S
    we replaced them and they blew as soon as we turned power on. Does anyone know what would cause this to happen
    Oct 2013
    57
    Re: VAC III D-11 SPINDLE DRIVE PROBLEM
    Odds are that the power modules ... or large transistors on the spindle drive board have shorted ... that's a classic cause of that happening
    Mar 2009
    31
    OK thanks i will take a look at them
    Mar 2009
    31
    Is VAC III unit just for the spindle drive. Which board is the spindle drive board
    Aug 2011
    2517
    the biggest metal box is the spindle drive.
    even if the IGBTs are blown the cause of the failure is almost always on the top board.
    if you look at the later VAC III spindle drives the lower board is identical and the top board is different (i.e. the previous top board had design issues).
    if you look at the latest VAC IV and VAC V spindle drives it is a completely new design and about half the size of the VAC III
    start here.....
    http://www.cnczone.com/forums/okuma/...fix-notes.html
    you will have a LED error on the actual spindle drive.
    get the manual linked on that thread and read up about your error.
    the chances of you fixing it yourself are about 1 million to 1.
    There are 3 options:
    1 buy a new VAC drive from Okuma (~$20k)
    2 get it professionally repaired or a refurbished exchange unit (~$6k)
    3 scrap the machine
    Oct 2013
    57
    Or Send it to me. I'm retired but still repair VFD's and drives
    Oct 2013
    57
    Attachment 232664 Is this what you have?
    Mar 2009
    31
    Yes is it a D-11
    Aug 2011
    2517
    tell us what the LED error is showing, and what the green/red/orange LED look like, or if red LED is on/flashing, or take a photo of it.
    Oct 2013
    57
    I suspect either there are no LED's on or the red LED is flashing .... this guy has a problem that won't be fixed without the drive removed and taken apart
    Mar 2009
    31
    Oct 2013
    57
    Duh ... If I continue to post .... perhaps I can get my other foot in my mouth
    Aug 2011
    2517
    the leds are too bright to read if they are on, flashing or off.
    need to know the 7-segment LED numbers, if M1, M2 and M3 lights are on, off or flashing.
  1. Spindle drive problem
    By KrausMotor in forum Tormach Personal CNC Mill
    Last Post: 02-20-2013, 05:55 AM
  2. Spindle Drive Problem
    By Zoni in forum Hardinge Lathes
    Last Post: 05-21-2011, 03:56 AM
  3. AC Spindle Drive Problem
    By leeng in forum Colchester Tornado lathes
    Last Post: 06-08-2010, 11:42 AM
  4. Problem with 6M spindle drive
    By BigDamo in forum Fanuc
    Last Post: 04-17-2009, 02:51 PM
  5. A different (?) spindle drive problem
    By zephyr9900 in forum Tormach Personal CNC Mill
    Last Post: 03-01-2009, 09:10 PM
