586,389 active members*
3,122 visitors online*
    Sep 2011
    G Code programming
    Hello All,
    I need to run two parallal linear axis together at different speeds. Can anyone suggest how to command into the G Code program for the same?
    Dec 2012
    395
    Re: G Code programming
    Can I ask what the reason for this is ?
    Heavy_Metal
    Apr 2007
    8
    each axis would have to be called a separate axis and not just a mirror. Is that how it is wired?
  1. G Code Programming Question
    By EdmillerM in forum G-Code Programing
    Last Post: 09-05-2013, 02:19 AM
  2. Help! need someone to help w/ some mach 3 g code programming
    By sconklin in forum Mach Wizards, Macros, & Addons
    Last Post: 07-01-2010, 01:53 AM
  3. M-code programming on Fagor CNC
    By aventure in forum G-Code Programing
    Last Post: 10-13-2008, 03:53 AM
  4. learning G code programming
    By ldaniels in forum Mach Wizards, Macros, & Addons
    Last Post: 05-08-2007, 07:47 PM
