586,358 active members*
3,448 visitors online*
    Nov 2006
    473
    Threading problems
    I had an oops today trying to do some threading.
    Here is what I did.
    I did all of this in 1 program, 3 blocks
    1 block. Center drill .125 deep
    2 block drill through a piece of 5/8 sq bar
    3 block. Tap a .25 tap in a floating tap holder
    When the tap started to thread the drilled hole, about 1/4 of the way through it started to slip. I hit the feed hold button nothing happened!!!! The z axis was still going down. I had to hit the e-stop to keep it from crashing .
    Does it always continue motion with the tap cycle ?
    Steve
    Oct 2004
    188
    Re: Threading problems
    yep, unless it is a new machine with ultimotion
  1. Threading Problems
    By Cletus in forum Colchester Tornado lathes
    Last Post: 07-17-2012, 08:50 PM
  2. Sodick AQ560 threading problems
    By Mark Roberts in forum EDM Discussion General Topics
    Last Post: 11-23-2010, 06:30 AM
  3. Threading problems
    By Delw in forum Uncategorised MetalWorking Machines
    Last Post: 07-01-2008, 04:29 PM
  4. Threading on a SKT 21 LM
    By JohnBV in forum Hyundai Kia
    Last Post: 06-10-2008, 07:02 PM
  5. M3 Threading problems.
    By rerod in forum MetalWork Discussion
    Last Post: 09-27-2007, 12:45 AM
