Hi
I'm working on a low budget solution.
I have a PC power supply, a stepper driver and a stepper motor and an arduino that I use to control the motor.
I have tested the motor using the 12v from the pc power supply as the power source, but the motor is running at a quite low rpm.
The pc power supply have only 12v outputs, but can drive a lot of amp's (much more than I need).
Can I use a voltage regulator to step up the voltage delivered to the driver, for example this one:
DC-DC Converter 12V to 48V 3A 144W Step-Up Power Supply Module (New DC Converter 12V to 48V 3A 144W Step Up Boost Power Supply Module Car | eBay)
I also assume that if I were to use this one, I could use it to supply power to a driver rated up to 3A, driving a motor up to 3A.
Am I understanding this correct?
