I'am new to cnc mill/drill/cut and wonder if the X6-1500 GT is a machine that will work out of the box. I'am thinking about buying a cnc router. While doing the research I came across this website with lots of info. After reading the post from user halebopp76 I got lost: http://www.cnczone.com/forums/chines...router-14.html
The post began positive but after a couple of comments, still usefull comments, I got lost in: exchange cards, spindle speed not matching, replacing pumps and what not.
So my questions are: Can I as a newbe work with this machine after assembly and install of all components that come in the package as a standard? Assembly won't be a problem.
Or do I need to replace things to get it to run as intended?
Thanks in advance!
Cheers
