For those who have a HiTorque mini mill or upgraded the column to one. Can you provide the dimensions of the column and the locations of the mounting holes please? I am thinking of the using the column on a hunk of metal to make my mill.
I have the solid column upgrade from Little Machine Shop but have not yet unpacked it from the shipping box.
If nobody else chimes in with the dimensions I should be able to check them for you, but it may take a day or so for me to be able to get to it.
Thanks. I tried searching the forum but no luck.
Please identify which dimensions you are looking for:
Attachment 232684
The location of the mounting holes, hole size and the general overall dimensions please
These are rough dimensions only:
Column height: 20-3/4"
Column width: 4"
Column depth (not including dovetail): 2-1/8"
Column depth (including dovetail): 2-1/2"
Base dimensions (not including dovetail): 6-1/8" x 2-3/4"
Base hole centers located at the corners of a rectangle 5-3/8" x 2"
Base hole diameter: 0.323" (P drill bit)
