586,345 active members*
3,132 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Stepper motor stalls while accelerating
    Apr 2014
    Exclamation Stepper motor stalls while accelerating
    Hello guys,
    This is my second attempt to run stepper motor using a driver I made myself.
    The first attempt was running the stepper motor with a constant speed and it was working fine.
    the second one -which I'm doing now- is accelerating the motor speed with a ramp profile, but the motor begins to lose steps and finally stops!! Attached is a video of when this is happening.
    The driver is 4 TIP122 NPN transistors driven by 4 2n2222 NPN transistors, which are isolated using opto-couplers from the microcontroller.
    The motor is unipolar stepper.
    please help me with that problem.
    Attached Files Attached Files
    Apr 2004
    5740
    Re: Stepper motor stalls while accelerating
    You might try reducing the acceleration until you stop losing steps.
    Andrew Werby
    Website
    Oct 2013
    57
    Try decreasing the power resistors by 10% ---- it will draw a little more current but should increase speed
  1. Motor stalls
    By Edgdais in forum Mach Software (ArtSoft software)
    Last Post: 01-28-2012, 02:38 AM
  2. easydriver + stepper motor stalls
    By scalance in forum Benchtop Machines
    Last Post: 12-19-2011, 06:34 PM
  3. Motor just stalls and vibrates!
    By prcdslnc13 in forum Stepper Motors / Drives
    Last Post: 12-02-2010, 01:58 PM
  4. stepper stalls out
    By edgara in forum DNC Problems and Solutions
    Last Post: 10-12-2010, 05:53 AM
  5. Stepper stalls, resonance, and voltage questions
    By boyvox in forum Stepper Motors / Drives
    Last Post: 08-09-2007, 10:19 PM
