586,283 active members*
4,015 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > Hitachi WJ200 + 400Hz spindle + resistor braking: anyone got it working?
Results 1 to 4 of 4
    Jun 2008
    15
    Hello - I've got a Hitachi WJ200 hooked up with a 2.2kw Chinese spindle and I just added a 200W, 50 ohm braking resistor that I can't get to work right yet.
    The problem seems to be with setting A052, which sets the DC braking frequency. This setting maxes out at 60Hz, but my spindle operates at 400Hz. Setting A052 to 60Hz does allow for braking once the spins down to 60Hz, but that can't be right.
    Has anyone gotten this combination working together that could share the relevant settings?
    Thanks,
    Kent
    Sep 2010
    1765
    Re: Hitachi WJ200 + 400Hz spindle + resistor braking: anyone got it working?
    sure people have those working. you are messing in wrong area - a52 is for dc injection braking - not db.
    since u can go to as low as 35ohm on resistor on that model you are ok at 50ohm.
    just set the right parameters; default is no db working.... it is B090 & b091
    Jun 2008
    15
    That did it! Thanks for your help. I set B090 to 10 and F003 to a one second deceleration. No heat on the resistor that I can tell. So far that is working pretty well so I don't want to push it further.
    Kent
    Sep 2010
    1765
    glad to help.... I have NEVER installed a vfd w/o setting it to use 100% DB capability.... interesting thought to limit it to 10% if you can....
  1. Replies: 30
    Last Post: 09-28-2016, 11:59 PM
  2. Braking resistor for spindle VFD?
    By SwampDonkey in forum Spindles / VFD
    Last Post: 02-27-2014, 04:40 AM
  3. Novakon Braking Resistor
    By iGAK in forum Novakon
    Last Post: 08-02-2013, 07:20 AM
  4. Braking resistor tip
    By LBodnar in forum CNC Machine Related Electronics
    Last Post: 05-16-2009, 01:24 PM
  5. Spindle Braking Not Working
    By TT350 in forum Tormach Personal CNC Mill
    Last Post: 01-26-2008, 11:15 PM
