586,471 active members*
3,375 visitors online*
Results 1 to 2 of 2
    Nov 2010
    2
    Question Stepper Motor Kits.
    I kits like the one below:
    kit Includes:
    3x ProboStep VX Uni-polar Stepper Motor Driver
    3x HT23-400-8 400ozin Stepper Motor
    PBX-2 Parallel Port Breakout Board
    24Volt 6.5Amp Switching Power Supply
    6ft. DB25 Male-to-Male Cable
    3x 4" IDC Cable 10-pin
    I look at the motor specs for this kit and each of these motors are rated at 4.2 amps per phase if wired in parallel. There are 3 motors here so that's 4.2 x 2 x 3 = 25.2 amps total. If they are wired in series then its 2.8 x 2 x 3 = 16.8 amps total. How can a 24v 6amp power supply be enough power to handle three motors?
    Wayne:drowning:
    35538
    Re: Stepper Motor Kits.
    One, you can only wire it unipolar with that drive, which is 3 amps/phase.
    Two. You don't add the amps for each phase, you only count it as 3 amps per motor.
    Three. With chopper drives, the drive typically will draw2/3 or less of the motors rated current, or about 2 amps per drive.
    Which all adds up to about 6 amps. And often, they will draw less.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. Complete Stepper Motor and Driver Kits - List and Reviews
    By enforcer in forum Stepper Motors / Drives
    Last Post: 11-14-2014, 01:30 AM
  2. are stepper motor kits on ebay any good
    By prupp in forum DIY CNC Router Table Machines
    Last Post: 06-23-2011, 04:47 AM
  3. stepper motor kits
    By deannos in forum DIY CNC Router Table Machines
    Last Post: 11-02-2010, 06:59 PM
  4. Stepper motor kits for me requirements?
    By Mindcore in forum Stepper Motors / Drives
    Last Post: 04-20-2010, 12:09 AM
  5. Stepper motor kits.
    By jkirkley in forum Stepper Motors / Drives
    Last Post: 01-28-2005, 02:55 AM
