586,903 active members*
2,840 visitors online*
Results 1 to 18 of 18
    Sep 2009
    277
    NCStudio Speed Limits????
    Hi all
    I have a XJ1212 running with NCStudio. I must say i have had absolutely NO issues and has been stable from day 1. I am running at 0.001 resolution on all axis. However this is probably TOO high.
    So i was looking at the specs - my machine should Jog at 7000mm/min and cut at 4000mm/min. The max i can set to in NCStudio is 2820. Any higher and I get an error when i click to apply the higher setting.
    I thought perhaps it was the resolution, which made sense, so i adjusted the drivers and NCStudio to 0.01 resolution. It still seems the max i can set NCStudio to is 2820.
    Any ideas?? Will be a HUGE help.
    Thanks.
    Re: NCStudio Speed Limits????
    Dear friend,
    How issues of setting pulse equivalent, please check manual
    https://www.dropbox.com/s/tsjuwn9ee5...B53C-R4.06.pdf
    Best Regards
    Sep 2009
    277
    Thanks Charles I got it sorted. How do I get the machine origin correct. Do I calibrate? How do I calibrate? I see the function.
    Quote Originally Posted by charles_weihong View Post
    Dear friend,
    Best Regards
    Sent from my GT-N7100 using Tapatalk
    Dear friend,
    About machine origin, is your Reference Switch working properly?
    Best Regards
    Sep 2009
    277
    I didn't know I had a reference switch. .. I really sound ignorant. If I select calibrate the machine moves to the start of X and y and then z moves down and I stop it so it doesn't damage my table. Maybe it won't?
    Dear friend,
    Enclosed are some instructional videos for Ncstudio, please take a look.
    https://www.dropbox.com/sh/290xz7p8vsjwgku/u0Ubqavg9Y
    Any question, you can reach me at My skype: charles.weihong.
    Best Regards
    Sep 2009
    277
    Thanks a million Charles. I'll go through them
    Sep 2009
    277
    Dear friend,
    Best Regards
    Hi Charles. I see this says V8. I have 5.5.60. Where do I get V8?
    Dear friend,
    Enclosed is Ncstudio V8 demo version, please check
    https://www.dropbox.com/s/mzrou1mmqh...6A_std_ex7.exe
    Best Regards
    Sep 2009
    277
    Thank you Charles. I got my v5 with my machine. Does one need to pay for V8?
    Dear friend,
    Best Regards
    May 2014
    9
    hello thanks to charles I try to install v8 of ncstudio but I have this error:
    File signature fail (this file may be broken ot infected by virus)! file signature: E159482B-F31C0700-C7844F0C-004040E1
    I try on 2 different pc with windows xp professional.
    I disabled firewall but it still doesn't start...
    Any idea?
    thanks :wave:
    Jan 2007
    1795
    this program using functions that similar as viruses.. your virusprotection or firewall gives false alarm..
    like in many other cases..
    beyond firewall something still don't let the program run.. please also note it is a trial program..
    Jan 2007
    1795
    shearder
    you have ballscrew and your ""speed"" will be limited by pulses..
    means when you set ""precision"" to 0.01 then you need more pulse per unit.. mm or inch..
    pci cards maxing out about 150 kHz....
    so you might change your settings back and you can use higher feedrates..
    Sep 2009
    277
    Hey victorofga I believe I am set to 0.00625 and I'm running a max that I set of 4000mm/min. I haven't tried faster or adjusting precision as I am pleased with current results
    May 2014
    9
    Quote Originally Posted by victorofga View Post
    I only have windows firewall that I disabled, and I use windows xp pro, how have I to do? Please...
    Jan 2007
    1795
    I don't know gpguit what programs you have installed on your computer..
    when you cant install programs that most likely settings problems..
    a controlprogram somehow differ from other programs like a wordpad...
    this program using direct output unlikely regular programs that working trough on windows drivers.. if you purchased a card from weihong then they going to help you.. Charles posted his email and his Skype... send him message, and if you weren't sure about your card then make a picture and send him..
    May 2014
    9
    thanks for your gentle reply.
    I contacted charles that sent to me software, but I didn't want stress him via skype on saturday and sunday... I guessed to solve via internet.
    Ok I will follow your advice.
    :wave:
    Sep 2009
    277
    Maybe a question for a new thread but is there an output on the stepper drivers or other that I can run a relay from to turn the dust collector on and off. Many times I go out and leave the machine to work but when I get back the job is done but dust collector is still running. It's a waste of electricity.
  1. NCstudio 4.XXX and 5.XXX
    By victorofga in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-22-2015, 02:06 PM
  2. ncstudio
    By jalal aw in forum Commercial CNC Wood Routers
    Last Post: 05-05-2014, 07:30 AM
  3. Setting up Config >Homing/Limits Dialog (Motor Home/Soft Limits)
    By CStevens6 in forum Mach Software (ArtSoft software)
    Last Post: 07-18-2013, 04:19 AM
  4. Trying to figure out the feed and speed limits on my mill
    By arrinick in forum Benchtop Machines
    Last Post: 10-19-2009, 07:57 PM
  5. what limits max speed?
    By srmaietta in forum DIY CNC Router Table Machines
    Last Post: 03-10-2007, 01:58 PM
