586,384 active members*
3,609 visitors online*
    Jul 2013
    84
    Unhappy Mach 3 - Driver Test results VMWare player (XP -> Mach 3)
    Hi Forumites,
    I have the following setup for mach 3:
    host 64bit win 7 ultimate SP 1
    vmware player 5.0.2 build-1031769
    Mach 3 installed on win XP pro sp3 (inside VM)
    I have followed optimisation.txt but it still looks like a mad cooks custard- any pointers (see images)
    Attachment 231298Attachment 231296
    Re: Mach 3 - Driver Test results VMWare player (XP -> Mach 3)
    Get a PC with a 32bit version of XP or Windows 7. Or get an external motion controller. You can't use the parallel port with Mach3 and a 64bit OS. And you can't run it in a VM.
  1. Factory test and results
    By TimM2 in forum Novakon
    Last Post: 05-23-2012, 01:42 AM
  2. MACH 3 PC test screen shots.
    By diyengineer in forum Uncategorised MetalWorking Machines
    Last Post: 10-11-2010, 05:51 PM
  3. Confused: Mach Turn, Mach Mill, Mach 2/3 ?
    By CanSir in forum Mach Software (ArtSoft software)
    Last Post: 02-16-2007, 11:41 AM
  4. Mach Driver test => Max 23,800Hz
    By haysys in forum Mach Software (ArtSoft software)
    Last Post: 12-18-2005, 08:12 PM
