I am at the wiring step of my Brother TC-225 Rebuild/Retrofit that you can see here for refrence.http://www.cnczone.com/forums/vertic...-retrofit.html
I am trying to figure out what kind of Wire I need for the Spindle motor power. and also how to wire in the noise filter I salvaged from the original electronics.
Heres whats going on:
Running a Yaskawa AC Spindle Motor # UAASKA-08LYA11 7.5kw
I don't have documentation On wiring this motor and any input would be greatly apreciated a few questions I have are: This is the closest I can find but only lists power cable for drive I dont have... http://www.yaskawa.com/site/dmspindl...IE-S626-6C.pdf
-What gauge wire do I need? where can I find it?
-What kind of sheilding do I need?
-I plan to run this through a cable chain from the electrical cabinet to the spindle, will i have problems runing the encoder cable, tool changer cables and limit switches in the same cable chain?
-What wire should I use for the encoder?
-The manual also mentions issue with switching with magnetic contractor, I have a large noise filter from the original machine electronics can I and how would I incorporate it?
The second part of the equation is the Baldor 10hp closed loop vector drive to run the spindle.
-Attachment 231164
-The drive manual lists 8ga wire for the drive, can i assume between drive and motor?
-it also recommends using fuses but there are many types what type would I use? and dose the fuse voltage have to match the incoming voltage(230V)?
Any help with this stuff would be greatly appreciated!
