586,341 active members*
3,593 visitors online*
Thread: Split G-Code
    Jun 2008
    21
    Split G-Code
    Is it possible to divide a nc file into two files for cutting? My machine maxes out at 99999 lines and I'm running quite a large cut that runs well over 99999 lines. Is it possible to somehow divide up the file so it does half and stops and then you can load the other half in to finish?
    Preferably free or dirt cheap!
    Many Thanks
    Jun 2008
    21
    Re: Split G-Code
    Sorry should add it needs to handle nc rather than ngc files
    Jun 2007
    3757
    Re: Split G-Code
    Yes. Just break it after a Z up command, put an M30 there, And continue with next program.
    You might need to restart spindle (S3) , as many controls turn it off at M30 (end of program)
    Jan 2007
    1795
    Re: Split G-Code
    built in windows notepad works very well..
    wordpad leaves unwanted characters..
    copy header into 2nd file... also the footer might has settings that you need to stick onto the first file end..
    Apr 2003
    3578
    Re: Split G-Code
    Why not drip feed the code?
    Cadcam
    Jun 2008
    21
    Re: Split G-Code
    Thanks guys. This worked perfectly!
  1. G-Code Ripper - Scale, Rotate and Split G-code
    By scorch in forum OpenSource Software
    Last Post: 08-26-2020, 03:28 PM
  2. Can someone split this ??
    By tubeguy in forum BobCad-Cam
    Last Post: 10-19-2012, 08:41 PM
  3. Split/NCS
    By gplush in forum Uncategorised CAM Discussion
    Last Post: 11-05-2009, 11:56 PM
  4. How do you split a project that is to big for your cnc?
    By dave8305 in forum WoodWorking Topics
    Last Post: 03-21-2009, 03:30 AM
