586,693 active members*
2,937 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > Parametric Programing > Fadal 88HS controller- program tip 56holes 7 sets in groups of 8- Thread milling
    Oct 2010
    Cool Fadal 88HS controller- program tip 56holes 7 sets in groups of 8- Thread milling
    Hi, I am programming to thread mill 56- 7/16-14 oversize (because the parts get anodized later and we don't want to mask the holes off) blind holes in 6061 aluminum. I have 7 identical parts that I get out of a slab of aluminum. Each part has a pattern of eight holes in a rectangular array so a total of 56 holes.
    What is the easiest way to create a sub-routine or sub-program so I can use just the one thread mill program that runs at all (56) the different XY hole locations? We center drill and drill all holes first. We have used a tapping head but we have had too many taps break so it has been decided to thread mill.
    I am on a 6030 Fadal VMC that does not have rigid tapping.
    Jeff
    Jan 2004
    3154
    Re: Fadal 88HS controller- program tip 56holes 7 sets in groups of 8- Thread milling
    Welcome to the Zone
    I have extensively posted on this subject in the past.in the FADAL section
    It is also in the manuals
    www.integratedmechanical.ca
  1. How to program thread milling?
    By Vegabond in forum G-Code Programing
    Last Post: 08-22-2011, 06:37 PM
  2. Fadal CNC 88 vs. CNC 88HS
    By jeff3 in forum Fadal
    Last Post: 01-31-2011, 02:53 PM
  3. Need help with thread milling program
    By Lukema in forum G-Code Programing
    Last Post: 10-18-2009, 05:10 PM
  4. Thread Milling - Cnc Program Developer - New Release
    By John Walker in forum News Announcements
    Last Post: 02-09-2009, 12:18 AM
