587,003 active members*
2,700 visitors online*
Thread: Time counter
Results 1 to 8 of 8
    Jun 2009
    146
    Time counter
    I have the program for the heating mashine.
    This is the example for fanuc:
    O7999(WARMING UP)
    G0G17G90G80G49
    G10L20P40X0Y0Z0
    G54.1P40
    (RPM ON BEGINNING)
    #511=1000
    (INCREASING THE VALUE OF RPM)
    #512=2000
    (MINIMUM DURATION IN MIN)
    #513=5
    (RPM UPER LIMMIT)
    #516=6000
    #3001=0(RESET OF COUNTER)
    #514=#513*60(MIN TIME IN S)
    S#511M3(RPM ON)
    #515=#514
    N11G1X0Y0Z0F3000
    G4P500
    X500Y600Z-200
    G4P500
    IF[#511GE#516]GOTO11
    #611=#3001(TIME 2)
    #614=#611/1000
    IF[#614LT#514]GOTO11
    #3001=0(RESET COUNTER)
    IF[[#511+#512]GT#516]GOTO12
    #511=#511+#512(INCREASE RPM)
    S#511(NEW VALUE OF RPM)
    GOTO11
    N12S#516
    GOTO11
    M30
    How should I do this in Siemens 840D?
    I know, how to programming with parameters, but I dont know, how to record the value of time and then compare?
    Jun 2009
    146
    Re: Time counter
    Maybe someone knows how to realize the counter to control sinumeric 840D?
    Or, for example, how do I do that the program will compare the two correction of ools, and if, for example. H1 of tool1 is greater than H2 of tool 1, displayed an error?
    May 2013
    37
    Re: Time counter
    F O7999(WARMING UP)
    S ;
    F G0G17G90G80G49
    S G0G17G90 MCALL D0
    F G10L20P40X0Y0Z0
    S $P_UIFR[40]=CTRANS(X,0,Y,0,Z,0)
    S $P_UIFR[40]=CFINE(X,0,Y,0,Z,0)
    S G540
    F (RPM ON BEGINNING)
    F #511=1000
    S R1=1000
    F (INCREASING THE VALUE OF RPM)
    F #512=2000
    S R2=2000
    F (MINIMUM DURATION IN MIN)
    F #513=5
    S R3=5
    F (RPM UPER LIMMIT)
    F #516=6000
    S R6=6000
    S R11=0 ;NEED FOR 840D
    F #3001=0(RESET OF COUNTER)
    S $AC_PROG_NET_TIME_TRIGGER=2;START COUNTER AND SET "$AC_ACT_PROG_NET_TIME"TO"0"$AC_OLD_PROG_NET_T IME NOT CHANGE
    F #514=#513*60(MIN TIME IN S)
    S R4=R3*60;(MIN TIME IN S)
    F S#511M3(RPM ON)
    S S=R1M3;(RPM ON)
    F #515=#514
    S R5=R4
    F N11G1X0Y0Z0F3000
    S _N11:G1X0Y0Z0F3000
    F G4P500
    S G4F0.5
    F X500Y600Z-200
    S X500Y600Z-200
    F G4P500
    S G4F0.5
    F IF[#511GE#516]GOTO11
    S IF(R1>=R6) GOTOB _N11
    F #611=#3001(TIME 2)
    S $AC_PROG_NET_TIME_TRIGGER=1;STOP COUNTER AND COPY $AC_ACT_PROG_NET_TIME TO $AC_OLD_PROG_NET_TIME AND SET $AC_ACT_PROG_NET_TIME TO 0
    S STOPRE
    S $AC_PROG_NET_TIME_TRIGGER=2 ;START
    S R30=$AC_OLD_PROG_NET_TIME;(TIME 2)
    S R11=R11+R30;(TIME 2) SUMARY TIME
    S STOPRE
    F #614=#611/1000
    S R14=R11;TIME IN S
    F IF[#614LT#514]GOTO11
    S IF R14<R4 GOTOB _N11
    F #3001=0(RESET COUNTER)
    S $AC_PROG_NET_TIME_TRIGGER=1;(STOP)
    S STOPRE
    S R11=0
    S $AC_PROG_NET_TIME_TRIGGER=2;(START)
    F IF[[#511+#512]GT#516]GOTO12
    S IF((R1+R2)>=R6) GOTOF _N12
    F #511=#511+#512(INCREASE RPM)
    S R1=R1+R2(INCREASE RPM)
    F S#511(NEW VALUE OF RPM)
    S S=R1(NEW VALUE OF RPM)
    F GOTO11
    S GOTOB _N11
    F N12S#516
    S _N12:S=R6
    F GOTO11
    S GOTOB _N11
    FS M30
    S-SINUMERIK
    F-FANUC
    Jun 2009
    146
    Re: Time counter
    Thank you for your comprehensive reply.
    I am interested in something, or maybe you know (you probably know) how the value of the parameter R (R5 = 103) stores, for example on 9th tool offset lenght compensation current (currently active) tools?
    For example.:
    T4
    M6
    I want now to save the value of r-parameter, and this is the 9th lenght offset tools from T4.
    So tool lenght offset D9 of the tool 4, There should be subscribed value from R-parameter (velue 103)...
    Sorry for bad english...
    May 2013
    37
    Re: Time counter
    I understand that you want to save the value of the variable "R" to some of the current number of the correction. Well I think? (my English is poor).
    Well here we go:
    I see it like this:
    Code:
    ;ISO G-Code Program
    ;G90 G00 G94 G17 G64
    T4 D9 M6;CALL TOOLS, CALLING THE CORRECTION NUMBER AND TOOL CHANGE
    ; $TC_DP6[m,n] - RADIUS GEOMETRY; m-tool number in whole mag table, n-"D" Number
    ; $TC_DP15[m,n] - RADIUS FINE; m-tool number in whole mag table, n-"D" Number
    ; $TC_DP3[m,n] - LENGTH GEOMETRY; m-tool number in whole mag table, n-"D" Number
    ; $TC_DP12[m,n] - FINE LENGTH; m-tool number in whole mag table, n-"D" Number
    ; $TC_MPP6[9998,1]-Table number actual tools (T4-not necessarily 4)
    ; $SP_TOOL - actual tools "D" number (should be 9)
    ; if
    ; r3 = 100; r4 =-0.1; r5 =-0.1
    ; when
    ; r3 = r3 + r4 + r5
    ; r3 = 99.8
    ; r4 = 0
    ;Logical? :)
    ;And so:
    ;Example for RADIUS
    $TC_DP6[$TC_MPP6[9998,1], $SP_TOOL] = $TC_DP6[$TC_MPP6[9998,1], $SP_TOOL] + $TC_DP15 [$TC_MPP6[9998,1], $SP_TOOL] + R5
    $TC_DP15[$TC_MPP6[9998,1], $SP_TOOL] = 0
    ;Example for length.
    $TC_DP3[$TC_MPP6[9998,1], $SP_TOOL] = $TC_DP3[$TC_MPP6 [9998,1], $SP_TOOL] + $TC_DP12 [$TC_MPP6[9998,1], $SP_TOOL] + R5
    $TC_DP12[$TC_MPP6[9998,1], $SP_TOOL] = 0
    ; After you make changes you will need to call again.
    D9
    or
    G1 G41 D9 X 10
    M17
    Jun 2009
    146
    Re: Time counter
    I really thank you for your comprehensive answer, I think this is what I want ... I tested how it works ...
    Jun 2009
    146
    Re: Time counter
    Jun 2009
    146
    Re: Time counter
    I have tested on the machine. This works perfectly.
    I have another question, I do not know how I define "GUD". Where should I define it and how to use it inside the program?
    I have to do special file, or define it in the program?
    If I use "GUD" variables probably do not need more R-parameters?
  1. Replies: 1
    Last Post: 06-11-2014, 02:53 AM
  2. Replies: 76
    Last Post: 04-24-2014, 01:42 PM
  3. Replies: 0
    Last Post: 04-24-2012, 01:46 PM
  4. long time reader first time poster
    By blu333 in forum MetalWork Discussion
    Last Post: 02-21-2010, 12:30 PM
  5. milling time (not to be confused with hammer time)
    By barefoot0 in forum G-Code Programing
    Last Post: 05-03-2007, 12:18 AM
