586,477 active members*
3,709 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > Hardinge chnc1 parts for sale
Results 1 to 16 of 16
    Oct 2006
    41
    I have hardinge chnc1 parts for sale . All the electrical parts and some of the air driven parts are getting changed out. Leave a post with email and as I get a chance I will get in touch with you. Just looking to get enough for new aftermarket electrical and drives
    Nov 2011
    39
    Re: Hardinge chnc1 parts for sale
    looking for CHNC II 16c collet closer parts / also i have a CHNC for parts
    ed
    Dear I need index stop mechanism control, in this mechanism I need one pneumatic control 4 way valve, R481-12 12 volt Dc valve made by CLIPPARD and one valve made by MEAD Chicago HT-100P, Please contact me at [email protected]. Tanks Masroor Anwar
    May 2009
    7
    would you have a plate to cover the micro switches on a hardinge chnc 1 i could send you a picture of what i need
    Nov 2011
    39
    Clamdigger,
    No but still have other parts ! Also have parts for a CHNC II with 810T control all boards ext.
    Thanks Ed
    Nov 2011
    39
    Clam digger,
    Found one !!! Came off a CHNC I 810T control . Got plate with switches and cover . [email protected]
    Ed
    Aug 2012
    126
    Have you still got the Interface board?
    Thanks, Allen.
    Nov 2011
    39
    Give me a #
    [email protected]
    Nov 2011
    39
    Allen,
    Yes ! Want to make sure they match !
    Ed
    [email protected]
    May 2009
    7
    Attachment 435806 hardinge chnc1 i am looking to buy L in the diagram
    Nov 2011
    39
    Looking for a X axis ac motor for a CHNC I
    Wiring diagram A13B-0139-8540
    Control GEF OTB
    CN-3085-T
    [email protected]
    Do have spare DC motors for CHNC II
    Nov 2011
    39
    CHNC I can't read the tag on the X axis AC fanuc motor to replace ! Can someone help please !
    Ed
    Sep 2010
    4
    Quote Originally Posted by Edwin Murch View Post
    ed
    Looking for the sheet metal base for early chnc
    Aug 2012
    126
    Hi
    Do you still need the I.d tags for the servo drives?, I removed mine for both
    X and Y motors so I could get info for a retrofit,
    And can sen pictures if you wish,
    Allen
    Jan 2009
    Allen,
    Ed
    [email protected]
    Don’t know if you found one, but unless you want to keep it all stock, I replaced that whole air assembly from Amazon for like $38. Nanpu I think is name. You loose your low-level alarm switch but what the hell. Actually I’m writing because with the stocker I had a problem with water getting past the drier cup and accumulated in the mist feed cup. Problem is, it draws up a tube from the bottom so ya end up feeding water, not oil. Not good.
    Feb 2010
    83
    Looking for the turret position switch/encoder for a CHNC II under the cover on the cross slide. Mine is encased in a resin body with 6 wires.
  1. Videos of my old CHNC1 making parts.
    By nate in forum Hardinge Lathes
    Last Post: 03-16-2013, 08:52 AM
  2. hardinge chnc 1 precision parts up for sale
    By hornby chopper in forum Bridgeport / Hardinge Mills
    Last Post: 07-29-2012, 05:59 AM
  3. Looking for /chnc1 parts
    By gdgambler in forum Want To Buy...Need help!
    Last Post: 05-17-2012, 05:50 PM
  4. 3x Hardinge HNC lathes for sale in CT
    By keitholivier in forum Hardinge Lathes
    Last Post: 03-31-2009, 01:21 AM
  5. Hardinge CHNC4 for retrofit or sale???
    By cbucner in forum Uncategorised MetalWorking Machines
    Last Post: 05-13-2006, 12:05 PM
