587,180 active members*
5,208 visitors online*
Page 2 of 8 1234
Results 21 to 40 of 149
  1. #21
    Mar 2013
    126
    Re: Upgrading a K40 moshidraw machine to DSp
    so this is the wrong power supply?
  2. #22
    Oct 2007
    385
    That is the wrong power supply for the DSP. That power supply will have a top amperage output of about 2.5amps. Of course, if the one you have can do the 24v 5a, keep it, it will work. The DSP and the associated electronics for it, require the 24v 5a supply that is provided in the upgrade kit. You do not have to replace the larger power supply, that is the one that provides power to the laser tube. Some of the DK40 machines do not have the same laser tube power supply that you already have, they need to purchase one that is PWM compatible. You have lucked out with that one you have, and so you do not have to fork over another $200 to replace your laser power supply. Tell Marco that you need the 24v 5a power supply, the DSP, and the 2 stepper drivers from the kit. Of course, you will need some wire and other small items that are available at RAT SHACK. I will try to take a picture of my unit after I did the conversion. I have also replaced the end stops In a different location. This gave me a little more cutting area. I also cut the piece of tubing on the left hand side of the guide rail short by about 1 inch. This gave me extra sized in that direction. There are many mods that can be done. I also made a manually adjustable honeycomb table. And 3d printed an air attachment. A lot can be done.
    Milt
  3. #23
    Mar 2013
    126
    Thank you Milt you have been a help! I am going to order the parts tomorrow.
  4. #24
    Oct 2007
    385
    No problem
    Milt
  5. #25
    Mar 2013
    126
  6. #26
    Oct 2007
    385
    Looks like it should work to me.
  7. #27
    Mar 2013
    126
    Cool, so I have ordered everything hope it comes in soon. I need the laser to make plaques for my van club by April 24. Do you have a copy of the program so I can see it?
  8. #28
    Oct 2007
    385
    Scottbgv--any update on the progress of your upgrade? Would like to know that you are getting along with it.
    Milt
  9. #29
    Mar 2013
    126
    I got the steppers and the power supply but I am having to wait on the DSP. I ordered it from china trying to save money and I am having a problem with them shipping it. they say they have shipped it but the tracking number has not showed any movement.
  10. #30
    Mar 2013
    126
    I did get the program and stuff to mess around with but it does no good without the actual DSP lol
  11. #31
    Mar 2013
    126
    got the dsp in the mail today!!!! headed outside to start putting it together wish me luck! I am excited
  12. #32
    Oct 2007
    385
    Take your time and make sure that all is connected correctly. NEVER plug in or unplug a stepper motor when there is power applied. Unplug the machine and let it be for a minute or so and then mess with the steppers. Good luck, and I am here if you need additional help.
    Milt
  13. #33
    Mar 2013
    126
    thank you I am sure i will be in touch.
  14. #34
    Feb 2014
    18
    I have a K40 laser that I would also like to upgrade.
    Does the DSP require special hardware like a dongle or special software like drivers etc.
    or can you drive the DSP with say GCode i.e. LinuxCNC?
  15. #35
    Mar 2013
    126
    no it just has a program it does require a little wiring and adding a couple parts not to sure about the gcode i am sure I am sure Milt can answer that
  16. #36
    Oct 2007
    385
    The DSP has its own software, but requires no dongle to operate. Marco, at Lightobjects.com, sends all purchasers of the DSP updates to the software when it is available. I use CorelDraw for most of my drawings. Corel draw files are exported to the laser program with a button in the Corel program. There are a lot of drawing extensions that are supposed to work with the DSP, but I have not tried most of them.
    Milt
  17. #37
    Mar 2013
    126
    doing pretty good so far will update here soon
  18. #38
    Mar 2013
    126
    ok when i take the resistor Green thing out do i just attach the wires together? is there away of wiring the optic limit switch in to the card ? does the wires on the other limit switch matter as far as they way they are hooked up?
  19. #39
    Mar 2013
    126
  20. #40
    Oct 2007
    385
    Yes, they will work. Radio Shack should have micro switches. Quicker than EBAY. Mount them on the top rails, one on the X and one on the Y. I mounted mine with hot melt. Did not want to start drilling into the frame.
    Milt
Page 2 of 8 1234
  1. Can anybody help me with Moshidraw Please?
    By Ranscon in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-10-2014, 06:57 PM
  2. advice for upgrading k-40 moshidraw to DSP
    By Eimantas in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-28-2014, 05:14 AM
  3. Upgrading dos machine
    By alan.styer in forum Commercial CNC Wood Routers
    Last Post: 06-12-2011, 02:36 PM
  4. Upgrading CNC controllers for an Anton Engelhardt CNC Metal Milling Machine
    By drosscr in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-17-2008, 01:47 AM
