586,459 active members*
3,311 visitors online*
Results 1 to 9 of 9
    6855
    Over all size
    How big it the foot print of the IH Turnkey CNC Mill ? I'm laying out my shop and need to know the width and depth I need for it.
    Jun 2005
    1015
    Re: Over all size
    about 4x8
    Jun 2013
    41
    Re: Over all size
    To allow for full travel on all axes you will need 40” Deep x 84” Wide x 93”High (on our 28" Tall stand). We can fabricate a custom height stand at no extra charge if necessary.
    6855
    Re: Over all size
    OK great my ceiling is only about 89" so I may need to modify the section that I'm going to put it.
    Jun 2013
    41
    Re: Over all size
    We can take 5" off the height of the stand, if you don't mind a lower than average table height.
    Mar 2012
    189
    Re: Over all size
    Could one of you flip the z servo so it hangs down instead of sticking off the top, or is that not the tallest point?
    -Jon
    Jun 2013
    41
    Re: Over all size
    Our new design (available in June) is direct drive. So flipping the servo is not an option. Even with that being the case, the top of the spindle motor is the highest point on the machine when the Z axis is at its upper most position.
    May 2008
    1185
    Re: Over all size
    If your a little short on height the mill will make its own space. Just type in Z=30 by mistake and you will have extra room.
    After that I lowered the stand by 3 inches.
    youtube videos of the G0704 under the name arizonavideo99
    Oct 2008
    2100
    Re: Over all size
    I did all the calculating I could on mine and I came up with a necessary depth of 50.5" to contain the servo motor on the front, and the electrical cabinet on the back. I opted to remove the electrical cabinet from the back and relocate it so I could make my base pan out of a single sheet of 48 X 96. With 2" rise on each wing, and a 3" lip everything fits with a couple inches to spare all the way around.
    Bob La Londe
    http://www.YumaBassMan.com
  1. How do I make CAD/CAM size match machined size?
    By RedCoder in forum Benchtop Machines
    Last Post: 12-07-2010, 11:13 PM
  2. Via shape/size and wire size.
    By Drools in forum PCB milling
    Last Post: 08-14-2009, 03:47 PM
  3. Drawing Size and Cut Size Differ - Plasma
    By ADucci in forum LinuxCNC (formerly EMC2)
    Last Post: 10-05-2007, 10:52 AM
  4. Drawing Size and Cut Size Differ - Plasma
    By ADucci in forum Mach Plasma / Laser
    Last Post: 10-04-2007, 02:49 PM
  5. X3 base size or minium bench size
    By kenrc in forum Benchtop Machines
    Last Post: 02-04-2007, 01:50 PM
