587,058 active members*
3,769 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > 90v 72v... worth worrying over?
Results 1 to 6 of 6
    Aug 2013
    194
    I could have sworn I found info regarding this, but can't find it anymore.
    planning on getting some 850oz DC Servos for the X/Y Axis on my zx45. Keling seems to not have any 90v for a while, I asked him if he would be getting any in, and he told me that the diff between 72v and 90v models wasn't significant.
    I am getting an 1125oz for my Z but then I ponder the same issue.
    Any thoughts?
    Jun 2007
    149
    Re: 90v 72v... worth worrying over?
    I'm using an old shunt welder with diodes and a large cap, makes a lovely hum when warming up!
    Aug 2013
    194
    Quote Originally Posted by elmerfud View Post
    how does that apply to the question?
    Apr 2012
    141
    Well you won't have as much torque/speed
    I was running at48v and should have been at almost double that ....
    Sold the machine... New owner installed a 60v and says it's a different machine now
    35538
    His question is a little vague, but he's not asking about power supply voltage.
    He's asking about two servo motors, one rated at 72V, and one rated at 90V.
    Looking at Keling's spec sheets, they took the specs from the 90V motor, and pasted 72V wherever it said 90V.
    If all other specs are identical, then running both motors at 72V should give nearly identical performance.
    The only difference would be that the 90V motor can handle 18 more volts, which gives you a little more rpm.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Apr 2012
    141
    pffft ... erm its late ?
    Taxi !!
  1. 9 x 20 cnc value. Has it been worth it?
    By sagespecialized in forum Mini Lathe
    Last Post: 01-31-2012, 05:07 PM
  2. Is Pro V.16 worth it
    By blvdbuzzar in forum Uncategorised CAM Discussion
    Last Post: 11-05-2010, 03:26 PM
  3. Used Slo-Syn - What are they worth?
    By mrgadgeteer in forum Stepper Motors / Drives
    Last Post: 02-22-2010, 04:55 AM
  4. This is worth what?
    By BR1AN in forum Haas Mills
    Last Post: 09-29-2008, 09:51 PM
  5. For what its worth...FYI
    By jer29_11_13 in forum Uncategorised MetalWorking Machines
    Last Post: 07-22-2005, 03:03 PM
