In a 2d tool path, i extract and select my edges for the profile. However, in some cases I want to allow the cutter to exit through the contour. I can do this by making those edges dashed lines. Is there something equivalent to this in 3 axis milling? I have attached a picture of a curve surface I am simulating. The generated tool path leaves a lip as it doesn't seem to want to let the tool go far beyond the extent of the surface.
I built the toolpath by selecting the top surface of my part as the geometry. Any and all advice appreciated.
Thanks much
Brian
Attachment 228694
