586,655 active members*
2,500 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Copying Profile from Top UCS into Custom UCS
Results 1 to 4 of 4
    Oct 2008
    65
    Have a complicated profile in the Top UCS and want to put it in multiple other Custom UCS's without having to redraw. I realize I can draw (redraw) any 2-D profile in the current (Custom) UCS and it will be in that UCS as opposed to the normal Top UCS. My question is; How do I copy/translate/rotate a Top UCS profile into another Custom UCS without having to redraw the profile or without having to "measure" the angles and rotate using those angles? I would like to simply copy/paste, but this does not work. Using V25 (current build). Thanks in advance for any help.
    Steve
    V28/29 4x Pro, Haas VF-3SSYT, Haas SL-30
    Dec 2008
    4548
    I think your stuck there. In the future, you want to reverse your workflow. Create your geometry, then rotate and move It to where you want it, then make your custom ucs off of that. Create a large plane around your first intial geometry and include that in your moves, then make the ucs from the plane.
    That's the best I have.
    bobcad guy Guest
    Re: Copying Profile from Top UCS into Custom UCS
    perhaps I misunderstand the issue but, cant you simply copy the geometry onto a new layer, then turn off the orig layer, and assign the new ucs to the new layer, and replicate that for each view you want?
    Quote Originally Posted by bobcad guy View Post
    The question as I understand it is how to get geometry from one plane to another in a custom UCS - imagine for instance a dodecahedron with each face a custom UCS, how to you get a design onto each face without working out the angular and spacial relationships between planes and then translating the geometry, it's an interesting one!
  1. cant get this custom tool profile to work.
    By i_am_joe in forum Mastercam
    Last Post: 03-18-2014, 09:16 PM
  2. Copying flat profile parts?
    By stonyme in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-12-2013, 03:44 PM
  3. Replies: 6
    Last Post: 06-21-2010, 09:33 AM
  4. Copying programs
    By jybute in forum Haas Mills
    Last Post: 05-07-2009, 10:58 PM
  5. copying in Autocad
    By skippy in forum Autodesk
    Last Post: 04-11-2005, 02:55 PM
