587,035 active members*
3,102 visitors online*
Results 1 to 2 of 2
    Jun 2012
    19
    Solidcam / Inventorcam 4th axis chamfer?
    Does anyone know how to make a tool path to make these chamfers highlighted in blue on the image that I attached? I have got all the machining down perfect except for these chamfers. I have a 4th axis that is parallel to the X-axis and will do both indexable and simultaneous.
    Oct 2007
    499
    Re: Solidcam / Inventorcam 4th axis chamfer?
    Do you have 5X or HSS in SolidCAM? If so, that would be my weapon of choice. If not, then a very small spotdrill and the 4X 'WRAP' strategy but it will not go right into the sharp corners
  1. 3 axis milling operation with a chamfer mill?
    By Brian Corwin in forum BobCad-Cam
    Last Post: 03-10-2014, 07:16 PM
  2. Chamfer template bug - Inventorcam 2013
    By glovebox20 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 07-18-2013, 12:01 AM
  3. tapped hole chamfer with iscar chamfer tools
    By dcutler35 in forum Mastercam
    Last Post: 12-07-2012, 02:30 PM
  4. anybody tried Inventorcam?
    By mattfurches in forum Uncategorised CAD Discussion
    Last Post: 06-22-2012, 11:55 PM
  5. hw to control a 3 axis, to do a chamfer in a tube...???
    By volvomech in forum G-Code Programing
    Last Post: 12-28-2011, 09:46 AM
