586,728 active members*
3,581 visitors online*
Results 1 to 3 of 3
    Mar 2014
    1
    Mitsubishi Mill Meldas 300 series control
    I started working at a new shop about three months ago. Since I got there this mill hasn't run. First the control was in Japanese after we moved. Then the table would not go operate properly after it was homed. After another round of repairs it is up and running. I am not sure how the canned cycles or the tool changer work. I tried to bore out a burned out hole with a canned cycle to no avail, i could not figure it out. I programmed the circular interpolation line by line by hand and changed tools manually. Is there anybody or anywhere with some sample programs I could see and teach myself what is going on. Thanks
    Aug 2007
    793
    Re: Mitsubishi Mill Meldas 300 series control
    what about reloading canned cycles from eprom after initialization?
    PLC I/F -> (1001)()(M) -> parameters -> base -> Fix_P = 1 -> data in/out -> input -> #(4) () -> "input" pushbutton -> PLC I/F -> (1001)()(U)
    Apr 2014
    9
    hi I work with the same machine if you post your code I can help you straighten it out. and teach you how to change tools
  1. Mitsubishi Meldas M3 Control?
    By Talisman in forum CNC Machine Related Electronics
    Last Post: 08-13-2019, 11:16 PM
  2. MITSUBISHI MELDAS 500 SERIES
    By el gordo in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-23-2013, 12:33 PM
  3. Mitsubishi Meldas M0 - Leadwell Westlake Series II - Parameters
    By trentbosch in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-03-2012, 02:35 AM
  4. Mitsubishi Meldas M3 control
    By Talisman in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-23-2012, 08:06 AM
