586,477 active members*
3,732 visitors online*
    Feb 2007
    64
    how to tell if encoder index is being seen
    I looked on the halmeter but I did not see anything other than index enable, which reads FALSE.
    I am trying to get the brushless servo motor to home properly.
    Feb 2008
    644
    Quote Originally Posted by js412000 View Post
    One way to test is put a halmeter on index_enable, setp index_enable true and then
    turn the shaft to see where index_enable gets cleared
    if it doesnt get cleared in one turn you probably have a wiring error
    if it gets cleared immediately regardless of shaft position, the index polarity is probably wrong
    Feb 2007
    64
    Thanks for the help. I resorted to the expedient of disconnecting the wires and then testing again. It is definitely finding the index just fine.
  1. Homing using limit and encoder index pulse?
    By purple_jeep in forum Dynomotion/Kflop/Kanalog
    Last Post: 07-09-2013, 06:09 PM
  2. Encoder Index Latching
    By Vector42 in forum CamSoft Products
    Last Post: 10-31-2010, 12:01 AM
  3. using encoder index for homing and a axes position
    By rokag3 in forum CNC Machine Related Electronics
    Last Post: 10-16-2009, 12:57 PM
  4. Looking for cheap encoder with index channel
    By JasonCampbell in forum Servo Motors / Drives
    Last Post: 09-13-2007, 03:31 AM
  5. Optical encoder index - what is it good for?
    By medved in forum CNC Machine Related Electronics
    Last Post: 10-03-2005, 11:26 PM
