586,455 active members*
3,329 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Cimatron IT 13 on Windows 7 64bit
Results 1 to 13 of 13
    Oct 2005
    37
    Hi All,
    Has anyone successfully installed Cimatron IT 13 on Windows 7, 64 bit system.
    Thanks.
    May 2004
    50
    Re: Cimatron IT 13 on Windows 7 64bit
    Dec 2014
    6
    Hi
    yep I did.
    PM if you need more info
    Bye!
    Feb 2015
    Quote Originally Posted by Teto_71 View Post
    Hi
    yep I did.
    Bye!
    Hi Teto;
    I would love some instructions. I am a licensed user, and like everybody else had to upgrade operating systems.
    Thank you,
    Steve
    Feb 2015
    Quote Originally Posted by aadonline View Post
    Hi All,
    Thanks.
    Hi aadonline;
    I too am faced with the same challenge. Please tell me if you were able to make it work. If so, I would really appreciate some instructions on how to do so.
    Many thanks,
    Steve
    Dec 2014
    6
    Hi all!
    sorry, I didnt conect for long.
    If anyone still interested, I can share.
    Bye
    16
    Hi All,
    Thanks.
    call me at 714 868 2037, wilson
    Aug 2016
    Hi all!
    Bye
    Hi Teto_71,I get the licend for cimatron IT 13 from al long long time and I'm really interested on find the way to use Cimatron it 13 on Windows X64 (unfortunatelly with Vmware it doesnt work properly)... please can you share instruction to do this?
    Thank you very much
    Dec 2016
    I've installed it directly on windows 7, but 32bits. I don't know if i could install directly in windows 7 (64bits) totally suceeded!
    In windows 32bits just try to install it with Administrator rights and in a compatibility mode, just say it worked in other OS versions and then select Windows XP SP3, i think that does it everything. You might get one or another issue but thats easy 2 solve with windows updates. Then install the graphics drivers last update and.... Good luck. One program that does not work is the launch panel for Cimatron 13 icons and tools. But if you double click the Cimit.exe or if you create a shortcut for it, it will work fine. To change the params of execution of Cimit, double click the Arguments.exe in the bin folder.
    EZ Good luck.
    Aug 2016
    Thank's. I finally istalled it on WIN10 X64 with no problem. Unfortunatelly there are graphics problems (NVIDIA GEFORCE) infact I get the black screen when I run it. If in settings I disable open GL everythings works ok but it's very slow. I tried also with MAC and Paralles but both on WIN10 and WIN XP installation I have the same problem. I think the only way is to find a PC with a Graphics board that support it.
    Quote Originally Posted by vascocrocha View Post
    EZ Good luck.
    May 2004
    50
    Is old post!
    Is anybody still using Cimatron IT?
    If yes do you do any electrodes?
    16
    Quote Originally Posted by Tulak View Post
    Is old post!
    Yes I'm still running Cimatron it12 bar
    On win 8.1 64 bits
    Het in touch [email protected]
    Oct 2022
    20
    hello i need cimatron 3 axis 4 axis and 5 axis posts. I also need an angled head post for 3 axes. For working in G18 G19 planes. Fanuc Siemens haidenhain please help. [email protected]
  1. Windows 7 64bit - Mach3 - ugh, one more thing to deal with now....
    By airbrush in forum Mach Software (ArtSoft software)
    Last Post: 03-08-2014, 08:14 PM
  2. Camsoft and windows 7 64bit
    By miran70 in forum CamSoft Products
    Last Post: 04-21-2013, 02:09 AM
  3. MasterCam X5 on windows 7 - 64bit
    By pearldiver in forum Mastercam
    Last Post: 07-27-2011, 03:21 AM
  4. Granite Drive with Windows 7 64Bit
    By speedydumpster in forum CNC Machine Related Electronics
    Last Post: 07-06-2011, 11:47 PM
  5. Camworks 2007 on a 64bit Windows
    By Andreas0815 in forum CamWorks
    Last Post: 09-28-2007, 01:50 AM
